[MOC] MAN TGX with Tanktrailer. RC/7w for Minifig Scale
Hello. I am proud to show you my latest trailer with a new tractor unit.
I have been building the MAN TGX since last fall: I kept rebuilding it because I wasn't satisfied with the result. Now it has reached a stage where I think it's ready to be shown here on Eurobricks without embarrassing myself ;-)
MAN TGX Zugmaschine 2.0 V71
I significantly improved the steering and drive of the MAN last fall, and my Scania trucks were also converted to this technology afterwards. Drive, steering, and control are handled by a Circuit Cube Bluetooth hub and two Circuit Cube motors. My truck is controlled via a Lego PU remote control (a microcontroller connects the remote control to the Circuit Cube via Bluetooth). This picture was taken at the beginning of the technical development. Later, I slightly revised the technology so that only the two motors and the Circuit Cube Bluetooth hub are third-party components. All other parts are from Lego.
Technik Zugmaschine 2.0
The truck is very compact, but I tried to capture a few details from the large MAN.
And then you need a suitable trailer. I already have a few box trailers, so I wanted to try something new.
It took me several attempts before I was able to build a good tank trailer.
Tanktrailer "silber" V06
The interesting thing about the tank trailer is the saddle support. This can be extended or retracted so that I can also couple the trailer to the truck and drive it.
The saddle support is operated by turning the last tank filler neck by hand. From there, an axle runs to the mechanism between the wheels and adjusts the saddle support.
(WIP) Tanktrailer V06 Mechanik
I really like the 2x2 curved slopes in metallic silver from Lego. They give the tank its metallic look and are real eye-catchers.
And with the MAN, it looks even better, don't you think?
Thomas
What a masterpiece, both the truck and the trailer! The mechanical features are just the cherry on top.
Which round grey piece did you use between the metallic sections of the trailer?
Thank You!
Most questions concern the light gray ring. But I must admit: it wasn't my idea. I had seen this part years ago on a steam locomotive as a boiler ring and remembered it.
The part is a brake disc from Lego Technic . It's difficult to install because it has various raised sections that tend to get in the way. But it's doable and, as far as I know, the only part that allows you to create a ring of this kind.
Break disc 65416
Thomas
It's crazy that you managed to install the saddle support technic axles through the little cutouts!
I actually wanted to use that exact same part for a cathedral rose window, but ended up abandoning the idea because... it looks too much like a break disc :P
The difficulty with the saddle support was that there is a central cross axis running through the middle of the tank that holds everything together. And now the vertical axis had to go through it too...
The brake disc as a cathedral window is also a cool idea. But I agree: in the end, it might look too much like a brake disc.
In my case, you can hardly see the brake disc at all, and you just wonder: what is that part...
Thomas
