After university, I worked as a geophysicist for six years. As a result, my usual work scenery often consisted of oil pump fields.
So when I read about a competition for non-transport mechanisms, I didn’t have to think long.
63
The first thing I decided to assemble was the beam and the horse's head. After putting the entire structure together, I had no regrets about how I connected them.
I had to spend a long time adjusting the beam's connection angles to effectively convert its rocking motion into the linear movement of the rod.
The second part of the assembly was the beam support. I decided to abandon vertical supports and made them inclined toward the beam. Then, I added a maintenance platform and a ladder running along the entire support.
66
The crank-slider mechanism made me spend a lot of time selecting the proper height for the crank attachment point, its length, and the length of the connecting rod to ensure the beam oscillated within the desired range.
I didn’t expect the counterweight to have such a significant impact on the uniformity of the entire structure’s movement—it was a real discovery.
I quickly added the motors, and the only question left was: where should I place the battery pack?
64
I had long thought that the shape of the battery pack resembled a transformer booth, which inspired the solution—to create a transformer and power line supports to supply energy to the pumpjack.
Finally, I put everything together!
60
P.S. I'm translating into English using ChatGPT, so there might be some mistakes :)
