Hmm. Do you think those front steering hub parts are just really worn on their pinholes? Or could it be the axles?
One thing that might help slightly, and wouldn't require new parts, would be to reinforce the front side of the attachment between the suspension arms and the frame. With them just being attached from the one side, you're giving up a bit of stiffness. Other than that, I'm not sure what else you can do, other than replace parts, which is understandably problematic if you don't have the parts handy
The pinholes are very worn on the front, but I will try reinforcing the swing arms. Soon I’ll look into buying new parts as well as the larger hubs and tires.
Thanks for the help
  • 2 months later...
