msk6003 Posted February 28, 2022 Posted February 28, 2022 This is my second 42131 CAT dozer's alternative model. This time I got idea from starcraft 2 siege tank. But because part limit of set, lot of part is look different with original model. Function Drive using 2 large angular motor Function drive/select using 2 C+ L motor 1. Siege mode 2. Gun elevation 3. Firing You need rubber band for gun system. I used 4 85546 yellow band but can use other band you have. All function is working by Powered up app. Quote
