swadley1992 Posted February 16, 2022 Posted February 16, 2022 (edited) Mercedes-Benz G Class SWB Diesel (W463)Power: 2 L C+ motors for moving, 1 L C+ motor for steering, 1 M C+ motor for diff locking.Weight: ~2.65 kg.Features: working V6 engine, planetary hubs, central differential locking, new differentials on axles, new type CV, 52 degrees climbing angle(56 with one hub), working headlights(W465 look).Model is based on @grohl_lego B-model (Zetros 42129). But there are many modifications:- Chassis in front is modified to put big V6 engine inside, second pair of springs is added to rear axle, second hub is used for lights/for external motors (trailer);- 2 speed gearbox removed. Central differential lock is added. 16/16 gear ratio is used;- Body look as @swiss_brick_garage made with some changes;- Interior rebuild. Seats from batmobile in black are added;- Non lego RC tires 1.55 85x28 are used for more realistic look and better performance. https://flic.kr/p/2n3UrNK https://www.flickr.com/gp/195008164@N05/2R1R16 https://www.flickr.com/gp/195008164@N05/76b57r https://www.flickr.com/gp/195008164@N05/f782W3 https://www.flickr.com/gp/195008164@N05/H3mLP4 https://www.flickr.com/gp/195008164@N05/e6d29R https://www.flickr.com/gp/195008164@N05/2RS50V https://www.flickr.com/gp/195008164@N05/g50L9j https://www.flickr.com/gp/195008164@N05/0bz9z1 https://www.flickr.com/gp/195008164@N05/vB5DdC Edited February 16, 2022 by swadley1992 Quote
Jurss Posted February 16, 2022 Posted February 16, 2022 Would be correct B-model for licensed set. Quote
gyenesvi Posted February 16, 2022 Posted February 16, 2022 Nice one, I definitely like the improvements on the bonnet and the front! I like those tires as well, they look pretty good, I have been checking them out before, but could not tell from images how well they fit. Do they fit the rims perfectly or is there a small gap? From the underside image, I can see that you are using an old CV joint as well in the front of the drivetrain. Did that ever pop apart if you drive it hard? Did you test this on outside terrain? Quote
Jundis Posted February 16, 2022 Posted February 16, 2022 Nice one! Grohl did a very similar B-model: https://rebrickable.com/mocs/MOC-92394/grohl/mercedes-benz-g-wagen-42129-b-model/#details Quote
swadley1992 Posted February 16, 2022 Author Posted February 16, 2022 23 minutes ago, Jundis said: Nice one! Grohl did a very similar B-model: https://rebrickable.com/mocs/MOC-92394/grohl/mercedes-benz-g-wagen-42129-b-model/#details It is based on this B model with changed chassis and body. (And 0.7-0.8 kg heavier)) 1 hour ago, gyenesvi said: Nice one, I definitely like the improvements on the bonnet and the front! I like those tires as well, they look pretty good, I have been checking them out before, but could not tell from images how well they fit. Do they fit the rims perfectly or is there a small gap? From the underside image, I can see that you are using an old CV joint as well in the front of the drivetrain. Did that ever pop apart if you drive it hard? Did you test this on outside terrain? Yes, in front I used one old CV joint combined with new one. Home tests are done. Climbing a lot up to 56 degrees, driving on pillows, and it's alive)) Quote
