gvo25 Posted July 9, 2021 Posted July 9, 2021 Hello everybody, To control my models with the new control+ motors I used the Buwizz app. Now that Buwizz app doesn't support the control+ system anymore, which app is the best to use now? Quote
kbalage Posted July 9, 2021 Posted July 9, 2021 You have a few options: On an Android device yon can simply download and install the .apk file for a previous BuWizz app version that still had the Technic hub support, e.g. from here You can use BrickController 2, a great and versatile app but it requires a game controller that is compatible with your smart device You can try other 3rd party apps like Controlz You can use the official Powered Up app. It requires some visual coding, but if the abilities of the BuWizz app were enough for you then it should not be really complicated to set up a profile. Here's an example tutorial to control 42124, and you can find a code block guide on my webpage Quote
gvo25 Posted July 9, 2021 Author Posted July 9, 2021 9 minutes ago, kbalage said: You have a few options: On an Android device yon can simply download and install the .apk file for a previous BuWizz app version that still had the Technic hub support, e.g. from here You can use BrickController 2, a great and versatile app but it requires a game controller that is compatible with your smart device You can try other 3rd party apps like Controlz You can use the official Powered Up app. It requires some visual coding, but if the abilities of the BuWizz app were enough for you then it should not be really complicated to set up a profile. Here's an example tutorial to control 42124, and you can find a code block guide on my webpage Thanks for the reply, it helped me a lot Quote
Andman Posted July 9, 2021 Posted July 9, 2021 Here are two more resources, which might be useful in the future: Quote
