TechnicBrickPower Posted January 13, 2021 Posted January 13, 2021 Here I've created my first attempt at a RC 3 speed gearbox allows you to change gears up and down using a power functions remote control. The gear changing mechanism is implemented using two parallel axles each with gears arranged in such a way that shifting one of the axles to one of three possible positions meshes the gears with 3 different gearing ratios. The gearing ratios implemented are 3:5, 1:1 and 5:3. The gear shifting axle is controlled by a lever mechanism driven by the 4 state stepper from the bugatti chiron set. This mechanism in turn is driven by a medium power functions motor activated by the remote control. Hope you like it. Quote
suffocation Posted January 13, 2021 Posted January 13, 2021 Brilliant work! You mentioned there's a problem with second gear, since the linkage doesn't align perfectly. Does this cause gear skipping under high torque? Quote
