Mechbuilds Posted September 28, 2020 Author Posted September 28, 2020 Okay front axle is done. And it's pretty rigid. It's a sad that the "wheel hubs" have a little bit of play. But i doubt it will matter during drifts. Quote
Sariel Posted September 28, 2020 Posted September 28, 2020 An alternative to RWD, found in real RC drift cars, is to use AWD but with the rear wheels geared to rotate slightly faster than the front ones. Also, I wouldn't put a differential on the rear axle at all. Quote
Gray Gear Posted September 28, 2020 Posted September 28, 2020 When spinning the back wheels faster than the front ones, what makes sure the rear tires lose traction, and not the front ones? Usually most of the weight is in the back, so there should be more traction there. The RC cars probably use tires with low grip in the rear... Quote
ukbajadave Posted September 28, 2020 Posted September 28, 2020 RC drift tyres are effectively solid shiny plastic but I used to put off cuts of PVC plumbing pipe over regular wheels. I'm sure you could do the same with Lego wheels. Quote
Mechbuilds Posted September 28, 2020 Author Posted September 28, 2020 2 hours ago, Gray Gear said: When spinning the back wheels faster than the front ones, what makes sure the rear tires lose traction, and not the front ones? Usually most of the weight is in the back, so there should be more traction there. The RC cars probably use tires with low grip in the rear... Well i'm probably going to tape the wheels anyway.. But i was going for 40-60 weight distribution. 40 at rear and 60 at front. I'll mount buwizz in the passenger side and the RC buggy motors will be mounted in the middle of the chassis. So the rear only has an empty trunk.. Quote
amorti Posted September 28, 2020 Posted September 28, 2020 Buwizz weigh like 50g each, they're hardly a way to ballast either end. Quote
Mechbuilds Posted September 28, 2020 Author Posted September 28, 2020 First test with 42111's tyres without tape. (very grippy.) 50/50 weight ratio. using two L motors with 24 tooth gears spinning one 8 tooth gear. (open diff at rear axle) I managed to out power the grip and actually spin a nice donut. Buwizz ludicrous mode. I can hear gears grinding. Possibly diff wanting to quit. Could also be the gear turning the diff. First test was promising. Next i will test having no diff at rear and gearing the front end 1.4:1 and rear end 1:1 and seeing if it will give me better results than 1.4:1 front and 1.4:1 rear. All this possible because it's only the frame currently. I'll probably go for two buggy motors to get at least a little bit of torque but heaps of speed. Still not completely sure if i should go with L motors instead? I want slow controlled drifts instead of just high speeds. Quote
MinusAndy Posted September 28, 2020 Posted September 28, 2020 Chuck some tape on the back tyres and try it, that could be the answer to what you’re looking for. The lack of grip at the back will take the load off the gears too. Definitely lock the rear diff! Quote
Mechbuilds Posted September 28, 2020 Author Posted September 28, 2020 Tested with 1.4:1 front 1:1 rear ratio. Definitely more slipping in the rear axle and drifting is easier. L motors are also pushing pretty nice power on ludicrous mode. I feel like it would be easier to control with taped tyres tho. I'm bashing into furniture. Next in line would be building the rear axle but i still don't have the buggy motors till next month.. So i guess i'll just have to wait. Quote
2GodBDGlory Posted September 28, 2020 Posted September 28, 2020 Cool to see the theory behind drift cars! I may have to build another one sometime! One thing I did once to lower traction on the tires was to cut an empty toilet paper roll into four quarters, and then put the cardboard around a 43.2 mm tire! Quote
Tazmancrash Posted September 28, 2020 Posted September 28, 2020 You could always go front wheel drive with trays under the rear wheels? Would be funny as hell. Quote
MinusAndy Posted September 29, 2020 Posted September 29, 2020 12 hours ago, Tazmancrash said: You could always go front wheel drive with trays under the rear wheels? Would be funny as hell. I believe that’s known as McDrifting. Quote
Mechbuilds Posted September 29, 2020 Author Posted September 29, 2020 I can only barely make the buggy motors fit: 2 is overkill right? Is one enough? Quote
amorti Posted September 29, 2020 Posted September 29, 2020 When it comes to drifting, I don't think "too much power" is a thing. Control it with brickcontroller2 to accurately apply less throttle if you're finding it spins too much. Can even set a max power limit if it's really too much. On the other hand, if you build it with one motor and find that with the weight of bodywork it doesn't have enough lead in its pencil, you're stuck. Quote
1963maniac Posted October 4, 2020 Posted October 4, 2020 (edited) Sam Wystrach uses this differential set up in his Crawler. https://rebrickable.com/mocs/MOC-51296/wystrach_sam/rc-crawler-4x4x4/#comments With this you can still drive an axle with a differential while it doesn't work as a differential. It has 2 half 2L beams with a 2L axle inside it. Edited October 4, 2020 by 1963maniac Quote
amorti Posted October 4, 2020 Posted October 4, 2020 Same in didumos's rocky. I've just done same in koncept mantis as it spit out a 12t gear from the diff, it's a 10t gear now. Quote
Gray Gear Posted October 4, 2020 Posted October 4, 2020 @1963maniac Why would you use a locked up differential instead of just using a gear? What advantage does it have, surely using a normal gear is much stronger? Quote
Mechbuilds Posted October 4, 2020 Author Posted October 4, 2020 5 minutes ago, Gray Gear said: @1963maniac Why would you use a locked up differential instead of just using a gear? What advantage does it have, surely using a normal gear is much stronger? The point is that when your front axle has a differential, you can't emulate that same gear ratio with gears. Differential uses 1.4:1 gear ratio. If you use gears, you'll get 1:1.. Which means that your rear axle would be spinning faster than your front axle. I'm still waiting for the buggy motors to arrive in the mail.. While i'm waiting, i'm constantly trying to figure out if i could still add a suspension and make it much bigger.. But then again adding stuff will make it harder and harder to drift.. Smaller the chassis, easier it is to drift.. Quote
amorti Posted October 4, 2020 Posted October 4, 2020 There's a 28t gear now, however it wouldn't be easy to fit it in a frame in the same way as a differential as it's not a thin gear. You could argue that's how they do it on real street drifters (welded diff) so it's valid here too. Quote
Mechbuilds Posted October 4, 2020 Author Posted October 4, 2020 14 minutes ago, amorti said: There's a 28t gear now, however it wouldn't be easy to fit it in a frame in the same way as a differential as it's not a thin gear. You could argue that's how they do it on real street drifters (welded diff) so it's valid here too. You can use the half 20t gear to power the 28t gear. So basically yeah if you have the new gear to use then sure it can be done with gears 100%. Probably will be a better idea since the diff is kinda flimsy. Quote
amorti Posted October 4, 2020 Posted October 4, 2020 (edited) Good idea. How did I not think of that? It would remove some play, as the locked diff part does have some slack in it. Edited October 4, 2020 by amorti Quote
2GodBDGlory Posted October 4, 2020 Posted October 4, 2020 47 minutes ago, Mechbuilds said: You can use the half 20t gear to power the 28t gear. So basically yeah if you have the new gear to use then sure it can be done with gears 100%. Probably will be a better idea since the diff is kinda flimsy. The trouble with that is that it will no longer fit inside an O-frame, so you would have to get creative with your bracing, and probably accept less strength. Quote
mktechniccreations Posted October 4, 2020 Posted October 4, 2020 Here is my take on mini drift car, buggy motor and no diffs, and new strong cv joints. Quote
Mechbuilds Posted October 4, 2020 Author Posted October 4, 2020 I can see that chassis having the steering pivot point more closer to the outer edge but you will have less steering angle when using the CV joint compared to the U joint. A video of that chassis working would be great! Kinda wanna build that and test it. Quote
mktechniccreations Posted October 4, 2020 Posted October 4, 2020 Tested, the buwizz wont handle ludicrous on RC motor, and its too gripy, will try something else Quote
