I would like to introduce my own control Solution: >>My Radio BLEuS << ( Bluetooth Low Energy useful System)
  • Powered by Arduino Nano 33 BLE Sense,
  • 4 x Power funtions port - 9V/1.5 A, each (optional updatable by that: Adafruit DRV8871 DC Motor Driver Breakout Board - 3.6A Max)
  • --> Keep in mind the technical requirements to provide ~ 130W by using max, current simulanoiusly , at all ports !
  • Not realy needed for an ordinary Brickset Car. In A MOC i would recomend; Battery, ESC, and BL Motors taken from "real" RC Motor Sports section.
  • power supply by PF Bat. box or internal 9V/ 1000 mAh Accu
  • Internal Akku has USB  charge connector.
  • Control options:
  1. Infrared, by using PF IR Transmitter
  2. RC Transmitter(up to 4 channel) supporting, "AFHSD2A"
  3. LEGO Powered Up App
  4. LEGO Control+ Profiles
Because of S-Brick published their protocol , it can be used with their mobile app , too.
Because of, Brickcontroller 2 app works with any  PU Hub, that is emulated by using profiles here, you can use Brickcontroller 2 app, also.
Additions:
SD Kart Slot for storing profiles , used by PU or Control+,......
Programming via USB Port, or JTAG connetor.
Supported Frameworks: Arduino, MBED,Nordic SDK
Note about Arduino Frameworks:
Works with ArduinoBLE, as well as Adafruit BLUfruit Libraries by using Adafruit Bootloader.
It is my new development base for next projects to come ;-)
Greetings Marc
Edited by ruppie
writing mistakes
