 ?‍♂️ now why didn't I think of that?! Thanks!!
Edit: I've just ordered all the parts from Bricklink/Lego - in quite a few cases, the parts from Lego were cheaper than Bricklink!
Edited by wg100
Wow, the building process is really one of the better recent models. It has come together nicely so far:
Included MODs:
- Huw's fix on the 8:8:8 transmission
- single clutch to prevent stress by rubber band, cf.
On 7/30/2020 at 10:18 PM, anyUser said:
Has anyone considered using pulley + 'rubber' instead of the 12/20 reduction next to the motor?
(I have used a #3482 wheel hub)
- single front wheel on a rotable mount for better steering on ground
What was your cost?
7 minutes ago, Klownicle said:
What was your cost?
I’m trying not to look at my bank balance... I’ve spent more than the retail price of the set that’s for sure! But I want to make this, so c’est la vie.
I'm going to have to look at the wheels on mine as well. The stock design allows for a 12mm maximum wheel radius. I don't have 6 wheels the same size that small, and my current interim solution has the plane hang backward a bit. I've got about 8 tires at 13mm radius, but obviously those don't fit.
I'm also probably going to do a lot of picking at colours before I post photos.
Hi,
Do you have a list of the part numbers and numbers needed to fix?
I would like to start building mine.
Thanks
2 minutes ago, dave88 said:
Hi,
Thanks
You can check out the part lists first post or import the XML code in the first post into bricklink.
What's your setup for the steerable front wheel? Can you share some photos?
With pleasure - On Step 81.3 on page 72 replace the 5L beam by this
plus a suitable 2L beam to fix the 5L axle in step 81.6.
The mount is assembled from these parts:
As the deployed wheel is not 'perpendicular' to the surface you will notice a small 'nag' (bump) any time the wheel turns by 180°.
Apologies if it has already been said, but you can order the Osprey parts from LEGO Bricks and pieces. Yes, including the exclusive ones. You just have to search for the part number.
Yep, there they are. Except the rotor blades are out of stock as of typing this. The new tapered panels should be available though. I didn't check for the recolours of older part types.
I could‘t order the following parts:
  • 6305550 Blades
  • 6303440 Panel
According to the customer service they will be available next year.
Edited by tismabrick
  • 6305550 Blades
  • 6303440 Panel
Second one is available on bricklink.
Guys, want to print the stickers does anyone know the size of the sticker sheet??? I have photo paper and a craft knoife, i got my first delivery of pieces yesterday 3 more on their way then i can build this, total spend was 530 AUD
You might want to check ebay for custom sticker sheets.
I had a look yesterday and none of the exclusive color variations showed up, were they pulled from B&P?
I have read in another topic they pulled the parts and cancelled the orders, but a friend of mine told me that his order with those parts have been shipped earlier this week.
Hi Guys, i have completed the build using the Lego Technic hub but cant work out how to turn it on, any help would be appreciated, the picure on page one of this forum isnt there anymore
Edited by Jester945
Brickshelf appears to be down (un-reachable) for the past few days. I put the images somewhere else.
(Sorry no direct linking because with some browsers mixing of https and external http servers is blocked by default and thus images not shown.)
