I got a 42099 recently and was kind of disappointed by the slow speed of the 6x AA nimh batteries (7.2V), so I made this 8x AAA battery box (9.6V, or 12V if you use alkaline). The speed boost was tremendous.
The fully charged 8x nimh batteries could reach almost 11.5V, but the voltage drops quickly. In theory it should be stabilized at 9.6V.
6x AA battery box.
The downside is 8x AAA will have less playtime than 6x AA. I don't know exactly how long you will get from this setup. I took the offroader to a park over the weekend and played 30 minutes without issue.
Did you make the battery holder or happen to find one that conveniently fit? Where did you get it? Do you have instructions? I would love to use this mod for the 42099 that I just put together.
I see you're using Eneloop batteries, which are high quality but expensive. Apparently Ikea sells the same batteries, branded as their own but for much lower price.
They are called "Ladda" in IKEA. AA are 2450 MAH, and AAA are 900 MAH.
Second this - we need to know more! Where did you get the battery holder? Can we get it somewhere ourselves, etc.
1 hour ago, dr_spock said:
Neat idea.  Looks a standard 8x AAA holder you can get off ebay with some metal tabs attached to it.  Is that what you did?  :classic:
Close enough, I actually glued 2 4x AAA battery holders together. The conductor pieces were made from a soda can. I will update some instructions later.
Do you think the higher voltage would eventually cause problems in the circuitry? I once hooked up a hobby 9.6V cell to a PF receiver, and the receiver didn't last long. Lego motors are supposed to take up to 12V (I have heard), but I don't know about control systems. If the PU hub can take it, though, that could be a very interesting high-performance solution!
Good ingenuity!
Must have some other cause,
less than 10% should not be a problem.
Good ingenuity!
Absolute max voltage for the LB1836M motor driver in the V1 PF IR receiver is 10.8V and allowable operating voltage is 9V at 25 deg. C.  DRV8333 driver in the V2 PF IR receiver has 10.8V for operating in the spec sheet.  Do the Power UP hubs also use the LB1836M motor driver?
Perhaps it had something to do with the fact that I was running nine motors off of it at once--A Servo, four Ls, and four XLs!
Yes they do use the trusty but voltage limited LB1836M chip. So going above 10.5V means taking risks!
Screenshots from the datasheet:
Edited by Philo
