28 minutes ago, TheNewGuy said:
The problem is the motorΒ moves along with it
I double checked and works fine here. Motor and plug are seperate pices.
In my end, when I select the plug and move or delete it, the motor is also affected. Any idea of the cause? I can’t seem to find anything related in the web
37 minutes ago, TheNewGuy said:
remove the plug and wire
Do you mean that you want to disconnect the wire from the motor?
There's no official way but you can pry the motor open and desolder the wires.
But than you haven't a working motor anymore.
Sorry I meant was just the plug with the wire sticking out. Because when I want to insert it to the space where I needed it to be, the plug gets in the way and can’t seem to separate it with the motor.
