Hey all LEGO Technic Builders,
First of all I'm an old guest member on this forum but today i decided to join this amazing Forum <3
I decided to male this topic which will be an index for all my LEGO Technic Tutorials i made on YouTube and it will be updated regularly when I publish any new content:
Hope this topic will be useful to you and positive feedback are very welcomed.
I know there are super professional builders here which i actually learn from them the art of LEGO Technic , their opinions will be so much appreciated :D
Thank you :)
1-  Adjustable Stiffness LEGO Technic Suspension (Shock Absorber/ Spring):
2- LEGO Technic Custom Pullback Motor Without Rubber Bands:
3- LEGO Technic Return to Center Mechanism using M-Motor and Shock Absorbers (No Rubber Bands!)
4- LEGO Technic M-Motor Steering Mechanism - Without Servo Motor:
5- LEGO Technic Working Exhaust System (First Prototype Test):
6- Improved Version: How to make a Custom LEGO Technic Shock Absorber (Spring):
7- High Precision Air Flow Control LEGO Technic Manual Pneumatic Valve:
8- The Simplest LEGO Technic RC Chassis Ever (Build under 15 minutes)
9- LEGO Technic Safari/Off-Roader Winch (Modular & Motorized):
10- The Magic of Hobson's Joint (Coupling) Done in LEGO Technic (SLOW MOTION):
11- LEGO Technic Steering Mechanism With Drive (Using Universal Joints!):
12- LEGO Technic Steering Mechanism Without Steering Rack:
13- LEGO Technic Pneumatic Braking System:
14- LEGO Technic Dog Gear Coupling Mechanism:
15- LEGO Technic High Precision Pneumatic Switch:
16- LEGO Technic One Direction Axle Rotation Mechanism:
17- LEGO Technic Simple Axle Lock:
18- LEGO Technic Custom Pullback Motor Version 2.0:
19- LEGO Technic Compact Arduino UNO Case Idea:
20- The Most Compact LEGO Technic Steering Mechanism (Tight Wheel Wells):
21- How to Build a LEGO Technic Custom Turntable with 3 Driving Options:
22- How to Build a LEGO Technic Mini Steering System (For Narrow Vehicles with Drive):
23- How to Build a LEGO Technic Realistic Car Clutch:
24- How to Build SCHMIDT Coupling in LEGO Technic:
25- Testing Schmidt Coupling in LEGO Technic :
More Tutorials will be added soon, THANK YOU ALL :)
Hi,
Welcome to the forum!
I was actually watching your video a few days ago, great work.
Regards Snipe.
  On 5/9/2019 at 10:36 PM, SNIPE said:
Hi,
Regards Snipe.
Expand
Thank you so much :D
  On 5/9/2019 at 11:16 PM, sirslayer said:
Been a fan of yours on the youtube for a while..it's about time you haved joined eruobrick!!
Expand
Thank you, hope you liked the content of the channel :)
  On 5/10/2019 at 11:57 AM, M_longer said:
That winch can't work properly, because white clutch gear will not block the winch in place. I have made different winch few years ago, have a look:
Front winch for 1:17 scale truck.
http://bricksafe.com/files/M_longer/winchtest.pdf
Expand
Great Creation, Thank you for sharing . i will try to build it and make a video footage of it in action :)
  On 5/12/2019 at 5:23 PM, M_longer said:
It was shown, as a part of bigger model:
Expand
This is a masterpiece :D .. Great work and design.
shame that I didn't discover your channel earlier, amazing content which deserve a lot more attention and views :D I subscribed
  • 2 months later...
New videos are available now:
1. LEGO Technic Custom Planetary Hub with Building Instructions
https://youtu.be/GqrS6Wzqbfs
2. Belts And Pulleys Installation Types: LEGO Technic Tutorial
https://youtu.be/mwtHLaSWTzE
  On 5/28/2019 at 12:23 PM, SNIPE said:
Here are some more cool ideas which you could put in your videos:
Reards, Snipe
Expand
Thank you so much, i will consider posting on your thread very soon ??
