1963maniac Posted January 7, 2019 Posted January 7, 2019 I would like to author a part that does not exist (just for my own use). I do not understand how the following is accomplished in MLCAD. How do you get to the LDRAW\parts\directory? from http://www.holly-wood.it/ldraw/authoring-en.html There is a portion that says: "The final code will look like this:0 Brick 1 x 20 Name: 3004.dat0 // Bottom rim4 16 20 24 10 16 24 6 -16 24 6 -20 24 104 16 -20 24 10 -16 24 6 -16 24 -6 -20 24 -104 16 -20 24 -10 -16 24 -6 16 24 -6 20 24 -104 16 20 24 -10 16 24 -6 16 24 6 20 24 100 // Inner box1 16 0 24 0 16 0 0 0 -20 0 0 0 6 box5.dat0 // Outer box1 16 0 24 0 20 0 0 0 -24 0 0 0 10 box5.dat0 // Inner Stud1 16 0 4 0 1 0 0 0 -5 0 0 0 1 stud3.dat0 // Top Studs1 16 10 0 0 1 0 0 0 1 0 0 0 1 stud.dat1 16 -10 0 0 1 0 0 0 1 0 0 0 1 stud.dat0Opening the official 3004.dat file in the LDraw\parts\ directory with MLCad or a text editor will show the same content differing only in the sequence of the code lines." Quote
Philo Posted January 7, 2019 Posted January 7, 2019 38 minutes ago, 1963maniac said: How do you get to the LDRAW\parts\directory First check where your library is located: in MLCad (assuming it is properly configured), Settings -> general -> change and see the folder containing the library. Copy and paste the field. Then File -> open -> paste the path in file name field, press open (to go in the folder), choose the file you want to edit, press open again. Note that it may not be a good idea to change a file in your library! make a copy first ;) Finally, if you get serious about LDraw part editing, use LDPartEditor, which is a MUCH better part editor than MLCad (even though I used MLCad during many years for that...) Quote
SylvainLS Posted January 7, 2019 Posted January 7, 2019 14 minutes ago, Philo said: even though I used MLCad during many years for that... And here I thought you wrote everything in one go with notepad Quote
Philo Posted January 7, 2019 Posted January 7, 2019 10 minutes ago, SylvainLS said: And here I thought you wrote everything in one go with notepad No, I'm not a real parts author Quote
1963maniac Posted January 8, 2019 Author Posted January 8, 2019 Thanks for your help Philo. Is there any tutorial or help files for LDPartEditor or more for MLCAD? The Holly wood it parts authoring content seems to be quite brief. Quote
Philo Posted January 8, 2019 Posted January 8, 2019 @1963maniac Yeah, we desperately lack good documentation - and LDPE beeing more recent, it's even worse. Probably the best documentation available for LDPE is here . Unfortunately, it's written in French, but hopefully Google translate can help... This website (written by a LDraw parts author friend) contains a heap of useful information about part authoring. You can also find some bits of information on my own website and on LDraw wiki . You can also ask questions on LDraw forum! Quote
1963maniac Posted January 9, 2019 Author Posted January 9, 2019 Thank you, Philo! I was looking for JC Jchang stuff but didn't find it. I was feeling a little underwhelmed by the help I found before this. Now?, not so much!! THANKS!! Quote
