BrickbyBrickTechnic Posted January 13, 2018 Posted January 13, 2018 (edited) I'm not sure if 2 stage tractor is the right term, but @Milan posted this beautiful picture at some point and some lights turned on in my head: CURRENT STATE: So I decided to build one. It will have the same 4 steering modes shown above. Referencing the picture down below, the yellow axle controls front wheel steering, parallel track, and combined front wheel and chassis. The black axle only controls articulated steering, in order to align the chassis to let the other modes work. Therefore, everything must be aligned in order for parallel track and combined front wheel and chassis. It is all controlled by a gearbox. Additionally, there will be a PTO and I will make a lawn mower attachment with 2 functions (both motorized). Here are some pictures. First (2nd-5th picture) are the 4 steering modes and then how they are controlled. Please excuse the photo quality: That's all. Please leave criticism and comments. I will post a video of steering soon. BbBT Edited January 25, 2018 by BrickbyBrickTechnic Quote
doug72 Posted January 13, 2018 Posted January 13, 2018 I congratulate you on in getting four steering modes. Doug Quote
Paknaloid Posted January 13, 2018 Posted January 13, 2018 You are a master of 42054, look forward to seeing how this progresses. quick question - are you still planning on making a slurry tanker or other trailer type attachment for your saddle trac c model? Im hoping to try and create a simple trailer for my set which has a single axle with 42054 wheels, either as a separate mini trailer or a single axle version of the saddle trac slurry tank. I haven’t been able to find a picture of this anywhere (probably as it isn’t realistic?). Interested on your opinion on this. Quote
Superkoala Posted January 13, 2018 Posted January 13, 2018 I don’t really understand the technical advantage of having a dual steering system on a tractor instead of a all wheel steer one with different modes. But You did your creation perfectly, I’m curious too see the final result, good continuation :) Quote
Aventador2004 Posted January 13, 2018 Posted January 13, 2018 Yes, I remember the Valta tractors mentioned, good luck! Quote
1gor Posted January 13, 2018 Posted January 13, 2018 So far steering modes are good, but IMHO your moc is to wide Quote
BrickbyBrickTechnic Posted January 13, 2018 Author Posted January 13, 2018 3 hours ago, Doug72 said: I congratulate you on in getting four steering modes. Doug Thanks 1 hour ago, Paknaloid said: You are a master of 42054, look forward to seeing how this progresses. quick question - are you still planning on making a slurry tanker or other trailer type attachment for your saddle trac c model? It's in the back of my mind- I know what pieces I'm going to use and how I'm going to build it. But first I must go on an alternate model spree (I've got a lot of ideas). 1 hour ago, Superkoala said: I don’t really understand the technical advantage of having a dual steering system on a tractor instead of a all wheel steer one with different modes. But You did your creation perfectly Thanks a lot! I'm not too sure about that myself (I'm not a tractor enthusiast ) but it was a good challenge to come up with an interpretation of the system. 1 hour ago, Aventador2004 said: Yes, I remember the Valta tractors mentioned, good luck! Thank you! 24 minutes ago, I_Igor said: So far steering modes are good, but IMHO your moc is to wide Thanks. I'll try changing the rear so it is less wide, or making the whole thing longer (the front is kind of locked in now due to all the mechanism, which is it's most efficient now after 6 iterations) Quote
1gor Posted January 13, 2018 Posted January 13, 2018 It's just my general complain (even my Unimog is half a stud to wide). Nevertheless it is interesting concept Quote
Jurss Posted January 13, 2018 Posted January 13, 2018 Some time I got this far there was also 4x4 drive. Stucked on gearbox, which could switch steering modes. Quote
1gor Posted January 14, 2018 Posted January 14, 2018 @Jurss and @brickbybricktechmnic perhaps my solution for New Holland supersteer could help you http://www.brickshelf.com/cgi-bin/gallery.cgi?f=504056 Quote
BrickbyBrickTechnic Posted January 14, 2018 Author Posted January 14, 2018 16 hours ago, Jurss said: Some time I got this far Looks like a very nice start! I see how you got stuck with it though. I assume to switch modes the axle with the 20z gears would slide? Quote
Jurss Posted January 14, 2018 Posted January 14, 2018 1 hour ago, I_Igor said: perhaps my solution for New Holland supersteer could help you It seems, that You have something different, articulated steering point is very close to front axle. Quote
1gor Posted January 14, 2018 Posted January 14, 2018 1 hour ago, Jurss said: It seems, that You have something different, articulated steering point is very close to front axle. It is a bit different but it is the same principle like on steering mode under number 2. just in my case whole exle articulates like front part of Valtra tractor Quote
BrickbyBrickTechnic Posted January 15, 2018 Author Posted January 15, 2018 On 1/14/2018 at 4:32 AM, I_Igor said: @brickbybricktechmnic perhaps my solution for New Holland supersteer could help you Not sure how that would help, but an interesting solution nonetheless. I have rebuilt the steering, and the solution is somewhat like that but not so close to the articulation point. Quote
1gor Posted January 16, 2018 Posted January 16, 2018 13 hours ago, BrickbyBrickTechnic said: Not sure how that would help, but an interesting solution nonetheless. I have rebuilt the steering, and the solution is somewhat like that but not so close to the articulation point. Articulated point as far away that is true, but it has same principle, now next step is to integrate CLAAS 3 way steering in this model to gain those steering modes Quote
BrickbyBrickTechnic Posted January 19, 2018 Author Posted January 19, 2018 Update: I have rebuilt the steering mechanism and added the front bodywork. Now, the steering mode gets controlled by a lever in the cab, which I think is great. That's all- comment below! Quote
BrickbyBrickTechnic Posted January 21, 2018 Author Posted January 21, 2018 Well, clearly no one cares about the front. How about a lawn mower attachment instead? It features 2 motorized functions. That's it! Quote
Aventador2004 Posted January 21, 2018 Posted January 21, 2018 All it is is there was more topics to look through, not everyone has hours to look through topics. It's good, keep working. Quote
aminnich Posted January 21, 2018 Posted January 21, 2018 I'll be honest with you, I didmr comment on the front because they are all startimg to look the same. BUT, the back is looking good! It looks like it is sticking out to far from the mower itself though. Quote
1gor Posted January 21, 2018 Posted January 21, 2018 Front looks good IMHO, it is simple, smooth and narrow as it should be. The only complain is that you have turned left tire the erong way. Rear attachment is good but I think it is unfinished Quote
BrickbyBrickTechnic Posted January 21, 2018 Author Posted January 21, 2018 4 hours ago, aminnich said: I'll be honest with you, I didmr comment on the front because they are all startimg to look the same. Makes sense. The last 3 have been tractor-type. But I try and change it up each time. After this I am taking a long, long break from 42054. 2 hours ago, I_Igor said: The only complain is that you have turned left tire the erong way. Rear attachment is good but I think it is unfinished Multiple people have pointed the tires out. I will change them but for now I am lazy. Rear attachment is a sketch to reserve the parts. It will be refined. Quote
1gor Posted January 21, 2018 Posted January 21, 2018 43 minutes ago, BrickbyBrickTechnic said: Multiple people have pointed the tires out. I will change them but for now I am lazy. Rear attachment is a sketch to reserve the parts. It will be refined. It's OK, the whole project is interesting because tractors are very interesting subject for mocs. Quote
MangaNOID Posted January 22, 2018 Posted January 22, 2018 17 hours ago, BrickbyBrickTechnic said: Well, clearly no one cares about the front. How about a lawn mower attachment instead? haha, you should try building a helicopter WIP... I'am half way through the tractor part of 42054 and I gotta say i'm loosing interest in it. I guess following instructions layed out for 10 year olds is hardly challenging. I love all these C models on this forum and tractor ones are great. this one is looking mighty good so far with very compact front end. I think I would rather build one of your c models than carry on with the A model. that last tractor you did looks great but ill wait to see what this ends up like before choosing and hope you will do instructions? all these tractors are inspiring me to do my own MOC tractor (but not c model) Quote
BrickbyBrickTechnic Posted January 22, 2018 Author Posted January 22, 2018 6 hours ago, MangaNOID said: this one is looking mighty good so far with very compact front end. I think I would rather build one of your c models than carry on with the A model. that last tractor you did looks great but ill wait to see what this ends up like before choosing and hope you will do instructions? all these tractors are inspiring me to do my own MOC tractor (but not c model) Thanks a lot! I will definitely be doing instructions for this MOC (though potentially not for a month or two). Tractors are fun builds (now I can say so myself). If you do find a nice tractor to build, just do it Quote
Sjoemie himself Posted January 22, 2018 Posted January 22, 2018 Another (LEGO) tractor fan here! I think you are doing an awesome job with all these c-models. Personally speaking i'm more a 'lurker' than a frequent commenter. That doesn't necessarily mean we are not interested in your creation though. Keep up the good work! Quote
