Hi there...can I fit  a 41678 Technic Cross Block 2 x 2 Split (Axle/Twin Pin) to 93274 Bracket 1 x 2 - 2 x 4 together in Lego Digital Designer
Like in the attached photo
Many thanks
Danny
No, you can’t. LDD only allows one-stud connections in technic holes. You can fill all the four hole-ends with 1x1 plates (or similar) but you can’t put a 1x2 plate (or similar), even attached by only one stud. (Strangely, you can’t even put a 1x1 brick while you can put a 1x1 brick round.)
Using two technic holes is illegal because the connection is considered too strong for a 7-years old to undo. Technic holes are a bit narrower than an antistud, so one stud is the limit.
And, yes, official models do use illegal techniques from time to time….
You can do this in Stud.io. I was able to do this in MLCAD and open it in "Stud.io". I don't think it a Stud.io file can be opened in LDD.  Just checked, it definitely cannot open saved Stud.io files.
Edited by 1963maniac
But probably you then get "illegal connection detected, piece was removed" or something.
