There is already a beautiful saddletrac MOC which was built by @efferman but I wanted to build a saddletrac using only pieces from the 42054 set. Here are the function:
-3 steering modes
-2 PTOs (1 top, 1 back & front)
-attachments, currently undecided
Here's what I've got so far:
IMG_5914
I did the front first specifically so I could ration DBG pieces.
IMG_5915IMG_5916
If you have any attachment ideas or constructive criticism, please leave a comment. Thanks!
BrickbyBrickTechnic
Edited by BrickbyBrickTechnic
How much of the inside is the same as the regular 42054? I never found time to try making one, I wanted to make without the same inside as the regular model. i envy your c model skills. Are any extra pieces used yet?
Where is the hog? Is it the grey gear? If so, move it or you will have no steering with a trailer attached!
Just the 3 steering modes. All else was changed because the BB needed to be lowered.
Nope.
Yeah, getting to figure that out.
31 minutes ago, M_longer said:
Nice model of Noirex 0005 SAALC!
I didn't understand your comment. What is a Noirex 0005 SAALC? Couldn't find a picture.
Look at your model. Then look at Lime panels above front axle. Then look at the sticker on it.
Just got that :laugh: Thank you!
I distinctly remember the same comment on my C model hauler.
53 minutes ago, BrickbyBrickTechnic said:
You mean steering knob? Yes, I will figure out a solution for that :thumbup:
Yes, this is causing me a problem. My wip xerion has fake engine and 4wd but steering is causing me a headachse. So I have finished Unimog chassis...
UPDATE TIME!
The actual tractor is done. Anyone have attachment ideas?
If you're wondering about the HOG steering knob, it seems like the trailer hitch is behind the HOG wheel. Check the above post and confirm this if you can.
Pictures:
IMG_5922IMG_5923
Here's the rear:
IMG_5924
The black thing is supposed to be the 3 point hitch... how does it look?
IMG_5926
Raised.
IMG_5927
Now, the big question: is the trailer hitch point where the finger is pointing?
Thanks for your answer!
BrickbyBrickTechnic
UPDATE TIME!
Pictures:
Here's the rear:
Raised.
BrickbyBrickTechnic
It looks ok at the first sight (remember that I stil have old smartphone :laugh: )
For attachment ideas I need few days to go to pc...
2 hours ago, Paknaloid said:
@BrickbyBrickTechnic Slurry slurry slurry slurry slurry!!!!
Oooohhh... looks good!
38 minutes ago, I_Igor said:
Perhaps something like this
Also an interesting idea!
From just the leftover pieces from the set, I'm building a lawn mower attachment. I will build the (cool) attachment (one of your suggestions) from other pieces.
There were only about 700 pieces left after finishing the tractor part.
I am loving this so far, i wish i had had the inspiration to build one. I just think, even replicating the real deal, the 3 point hitch is not good. it will not be easy to attach a crane, lawn mower, or get in the way of the trailer.
I don"t like the rear light angle, it looks to bend pieces.
Thank you! I do plan to restore the original PTO setup since the attachment I'm doing with the leftover pieces will have to attach there to ensure good weight distribution.
The rear lights don't bend pieces (they're attached to "hinges") but I'm looking into a better solution.
I was saying it looked like they were, I prefer original attachment.
@BrickbyBrickTechnic About steering knob - you can use 4 of these to make HOG from cabin...at least I'll do it on my saddle trac version
another attachment ideas...
zunhammer_claas_xerion_4000_selbstfahrer
... because I do not know if yopu have another pair of Xerion wheels I did not suggest you to make something like in this post
Worth buying another pair of wheels to make that badboy :laugh:
