Just now, Doug72 said:
Agree but they were the only large tires I had at the time.
that is normal and because you are limited with LA size
Small progress, building the rear axle assembly. Although it is unconventional in building directions (every connections are vertical on the shafts), it feels rigid enough.
EDIT: and the front pendular axle is also on the way:
Edited by agrof
Some progress, build ability and pneumatics testing. As assumed, the hoses will cause some head scratches yet, but I will do my best to hide them.
Tigercat is starting to take shape. For pneumatic hoses I suggest use blue part for additional pneumatic hoses as on front and back from LEGO Unimog U400 as much as possible :wink:
Thanks I_Igor, that is the plan, in the grapple boom it was easy to hide the hoses, I need to figure out the most nicer arrangement for the main cylinders + make it match for the steering system. We will see.
It could end very nice project :thumbup:
Another small progress, due to the place needed for pneumatics, I don't plan to add fake engine for the moment, but from the beginning I had an idea to give another nice touch in return.
Hereby I reveal the "secret" function: https://www.tigercat.com/feature/turnaround/
At the moment I don't see, how can I integrate the steering system, as worst case scenario I will just leave it off. Luckily the articulated systems are easy to control by twisting the hood or cabin, and I keep the main focus here on the playability.
EDIT: pictures about the the turnaround system, it relies on simple linear clutch mechanism. The plate with pin underneath the seat is frictionless. What I am surprised too a bit, how well the joysticks (lightsaber hilts) fit into the 3799.t1.png, pretty stiff connection, I can disconnect the whole seat assembly by pulling them.1280x720.jpg1280x720.jpg
Edited by agrof
