mocbuild101 Posted July 15, 2017 Posted July 15, 2017 (edited) I don't know if it would help, but you might want to have a look at the gearbox collection thread - you might be able to find a stronger gearbox or some ideas... Edited July 15, 2017 by mocbuild101 Quote
PorkyMonster Posted July 16, 2017 Posted July 16, 2017 @MattL600, do u have two of these? if you have, then you can modify @Didumos69's gearbox (just take the gearing portion): to use the parts you have - it'll be more compact and gives the same gearing ratio, i think. Most importantly, its arrangement allows for stronger bracing of all gears. Quote
MattL600 Posted July 16, 2017 Author Posted July 16, 2017 1 hour ago, PorkyMonster said: @MattL600, do u have two of these? if you have, then you can modify @Didumos69's gearbox (just take the gearing portion): to use the parts you have - it'll be more compact and gives the same gearing ratio, i think. Most importantly, its arrangement allows for stronger bracing of all gears. I don't think it'll work because the shifter has a half stuf offset. I'm planning to make an fix so that the frames are closer together and the half stud offset sticks out of the 4 tooth gears a little. Quote
MattL600 Posted July 17, 2017 Author Posted July 17, 2017 Project update: Cancelled... :( There are delivery issues with the servo motor which i believe will make the project very disadvantaged... The project may be revived if the motor does not arrive in 3 weeks... RIP Quote
BrickbyBrickTechnic Posted August 16, 2017 Posted August 16, 2017 3 hours ago, MattL600 said: Failure number 1 :( That's too bad :( I'm finishing up my mocs before starting my entry. Quote
MattL600 Posted August 16, 2017 Author Posted August 16, 2017 26 minutes ago, BrickbyBrickTechnic said: That's too bad :( I'm finishing up my mocs before starting my entry. You know what? I'll give it one more go, I hope this works out... Could even be a wacky superjet if car lol Quote
