Since i cant testdrive my newest speedracer because of the rainy weather, i decided to clean up my "in progress moc corner" and found this:
A as small as possible electric doubleswitch, wich you can use, to control 2 different motors with the same RC output.
You can simply select wich one you wanna use. At the same time you can use it to control a gearbox, or output-selector, as you can see in the video.
The idea to invent this, was, to realise as much functions as possible in a rc-model, with a limited amount of receivers (in my case just 1 RC-unit).
You can use the auxilary output of the RC-unit to control the micromotor, and thus switch between 2 different functions ( for example drive and a pneumatic compressor).
The output-selector can be used, to switch for example a servormotors output between steering and pneumatic-switch.
"Why so complicated, you could just use the auxilary output for the compressor"
-> well... you could do that and beeing limited to the auxilary current limits (~500mA). Also you wont have the gearbox/output-selector then ;)
While using this, you can power your compressor (or what ever you want) with the "unlimited" power of the RC-units buggy-motor-output. AND fine-controll it with the 3-step forward, 3-step-reverse-control.
It is also possible to control this with the RC-units steering output instead of the micromotor... like that you still have the auxillary-output free for use.
How it works:
The trick here, is to angle the 2 switches axles by 60 degres (45 would be perfect, but this is ok ;)).
But you need to try the right 60 degres angle... only 1 position works, otherwhise you will have 1 motor switched on in one position, and 2 motors beeing on in the other position.
The gearbox/ output-selector in the video can be simplified a lot, this is just to show, how it could work.
I am pretty sure, there are some more things you could do with it... also with regular power functions ;)
Edited by TechnicSummse
