Didumos69 Posted May 12, 2017 Posted May 12, 2017 (edited) Sequential AWD 4-speed gearbox with V8 fake engine Features - AWD with center differential - Sequential 4-speed gearbox - One-finger shifter - V8 fake engine This gearbox is an excerpt from my rugged supercar project. The mid-console has an important role in the overall stiffness of that model. It had to be narrow as well. If you build (have built) it, you will also notice it has very little torsional flex. I wanted a 4-speed sequential gearbox covering a wide range of ratios. So not something like 1:2.5 upto 1:1, but rather something like 1:3:5 upto 1:0.8. Another requirement I had, was that I didn't want red clutch gears to transfer drive on axles rotating at different RPM. This is a common practice, but from modding the Porsche I know it induces a lot of friction on the axles involved. When not engaged, red clutch gears better only make dummy rotations and not transfer drive. And finally, all had to fit underneath the engine; I didn't want the gearbox to be routed through the entire chassis. Instructions available on Rebrickable.com. Have fun! Edited May 14, 2017 by Didumos69 Quote
mocbuild101 Posted May 12, 2017 Posted May 12, 2017 Great gearbox! I like that you added a V8, which is something different. Will build! Quote
Alex Ilea Posted May 12, 2017 Posted May 12, 2017 I will mod it to be an 8 speed hopefully :) thx for instructions !! Quote
BusterHaus Posted May 12, 2017 Posted May 12, 2017 (edited) I recommend building this gearbox. It's very fun to play with. Very little friction, smooth shifting and the gear ratios are well displayed through the moving pistons. Edit: Just noticed that this version doesn't have the engine connected, it's pretty easy to do. Edit 2: need more coffee. Edited May 12, 2017 by BusterHaus Quote
Didumos69 Posted May 12, 2017 Author Posted May 12, 2017 (edited) 5 hours ago, mocbuild101 said: Great gearbox! I like that you added a V8, which is something different. Will build! Good luck! 25 minutes ago, IA creations said: I will mod it to be an 8 speed hopefully :) thx for instructions !! I would be very interested! 23 minutes ago, BusterHaus said: Edit: Just noticed that this version doesn't have the engine connected, it's pretty easy to do. It should have the engine connected. What makes you think it doesn't? Edited May 12, 2017 by Didumos69 Quote
BusterHaus Posted May 12, 2017 Posted May 12, 2017 21 minutes ago, Didumos69 said: It should have the engine connected. What makes you think it doesn't? Lack of coffee. My mistake, apologies for the confusion. Quote
DugaldIC Posted May 12, 2017 Posted May 12, 2017 Looks awesome @Didumos69, so smooth and fluid. I'd really like to build it at some point, maybe build a HOG model from it (as the crowds gasp in horror, Dugald, manual, noooo ) definitely one of the cleanest/refined shifters I've seen! Quote
Meatman Posted May 12, 2017 Posted May 12, 2017 Love it! This makes 2 cool new gearbox ideas that I've seen this week with the other being a left/right push button hog changer with r-n-d shifter. Quote
Aventador2004 Posted May 12, 2017 Posted May 12, 2017 2 hours ago, DugaldIC said: ,maybe build a HOG model from it (as the crowds gasp in horror, Dugald, manual, noooo ) yes, i very much dont like to not use my pf i bought. Quote
Alex Ilea Posted May 12, 2017 Posted May 12, 2017 Just built it and wow , it is so sturdy . Great build , thanks :) Quote
offroadcreations Posted May 13, 2017 Posted May 13, 2017 (edited) Wow, this seems close to, if not perfect! Shifts flawlessly every time, extremely robust, compact.... The list goes on and on. I'll have to build this for sure! @Meatman Would you mind sharing a link to this other one? Edited May 13, 2017 by Offroadcreat1ons Quote
Leonardo da Bricki Posted May 13, 2017 Posted May 13, 2017 This is excellent, works dang near perfectly! Very robust, sturdy, etc. Quote
mocbuild101 Posted May 13, 2017 Posted May 13, 2017 1 minute ago, Jurss said: Is there thread for geraboxes, like for axles? There is one for axles: Quote
Jurss Posted May 13, 2017 Posted May 13, 2017 I know about axles thread, but I haven't seen about gear boxes, what could be also usefull Quote
mocbuild101 Posted May 13, 2017 Posted May 13, 2017 It might be worth starting one, gearboxes are a popular subject . Quote
Didumos69 Posted May 13, 2017 Author Posted May 13, 2017 (edited) Thanks to everyone for the kind replies! 14 hours ago, DugaldIC said: I'd really like to build it at some point, maybe build a HOG model from it (as the crowds gasp in horror, Dugald, manual, noooo ) If you make a HoG model, I will make an RC model, I promise . 13 hours ago, Meatman said: with the other being a left/right push button hog changer with r-n-d shifter You're making me curious, do you have any links to that gearbox? 11 hours ago, IA creations said: it is so sturdy 6 hours ago, Offroadcreat1ons said: extremely robust, compact.... 3 hours ago, Leonardo da Bricki said: Very robust, sturdy, etc. The mid-console has an important role in the overall stiffness of the model for which I developed this gearbox. It had to be narrow as well. If you build (have built) it you will also notice it has very little torsional flex. 2 hours ago, Jurss said: Is there thread for geraboxes, like for axles? I could start one with this as a first entry and see what happens? Edited May 13, 2017 by Didumos69 Quote
Meatman Posted May 13, 2017 Posted May 13, 2017 (edited) 9 hours ago, Didumos69 said: You're making me curious, do you have any links to that gearbox? Hmm. There were 2 pictures of a chassis on the technic facebook page 3 or 4 days ago, but I cannot find them anymore. Apparently they were deleted because I "liked" them, but when I go back to my history, they are not there. It was a front engine mount with what looked like a HOG steering in the rear and buttons made form liftarms on each side with springs, and there was a pointer in the middle(like a clock) that showed the gear. I am pretty certain that it was Paul's. He shared a picture with me last year of something similar to this, but this looks completely different. The suspension was also different from anything that I had seen before due to the shock placement. The center console shifter had 1 x 1 square R-N-D tiles on the driver side of it. Edited May 13, 2017 by Meatman Quote
Didumos69 Posted May 14, 2017 Author Posted May 14, 2017 18 hours ago, Meatman said: Too bad. If it's Paul's, I hope it will end up in his next build. Quote
DugaldIC Posted May 14, 2017 Posted May 14, 2017 You sir have a deal! it'll be something entirely out of our comfort zone. Quote
Aventador2004 Posted May 14, 2017 Posted May 14, 2017 On 5/13/2017 at 3:27 AM, Didumos69 said: you make a HoG model, I will make an RC model, I promise . That sounds like a challenge, if it was a supercar competition I would lose to both of you. I think I've my collection isn't enough to make a proper supercar. Quote
Jeroen Ottens Posted May 14, 2017 Posted May 14, 2017 2 hours ago, Didumos69 said: Too bad. If it's Paul's, I hope it will end up in his next build. I made something like that in my BMW 328 Hommage The gear shifter can move side to side to switch between D-N-R. And when it is in D it can move forward and backwards to switch the gears up and down. When in R it is always in the same gear ratio and when in D it has a stop in it to prevent switching from 1 to 4 or vice versa. Quote
aeh5040 Posted May 14, 2017 Posted May 14, 2017 Wow, looks awesome. I'm going to try this right away... Quote
Didumos69 Posted May 16, 2017 Author Posted May 16, 2017 On 14-5-2017 at 1:14 PM, DugaldIC said: You sir have a deal! it'll be something entirely out of our comfort zone. Deal! On 14-5-2017 at 7:15 PM, aeh5040 said: Wow, looks awesome. I'm going to try this right away... Thanks! I'd say, build it and let us know your thoughts! Quote
