I've started a large project, wish me luck. I'm using a Kenner model as a basis, and I will try to cram as much detail as possible into this creation. I'm working from the bottom up. Please offer any advice or criticisms as you see fit.
Is this gonna be UCS size? If so, I wish you luck. It looks really good as is, but one thing I might suggest is to mess around and try to have the studs face up instead of down. There's a one plate solution so that within a single brick you have studs facing both directions. I would recommend that so you have a smooth bottom, and then a solid building platform. Anyways, happy building!
