Hello,
I have a few rechargeable battery packs and for some reason the power function lights do not work when plugged directly into battery pack.
I have tried 2 different battery packs and also about 3-4 lights and non work.
Does anyone have any idea what I am doing wrong?
Im really confused and getting frustrated.
Thanks
if you conect the lights directly to the battery then yes you are, else the battery is sitting in idle and doesn't put current on the lights (or if you connect a motor, it too will not run unless you turn the little switch). It's different with the revievers, with those it's the reciever that does this job.
