Showing results for tags 'spark industries'.
Hello I like to share the result of Spark Industries' new side project. The company produces modern locos and cars, but wants to salute the old times. So designed a steam engine with enthusiasm and love. She is a 4-6-4 Hudson type loco: There wasn't a particular real loco for modelling, but the main shape based on Canadian Pacific 2816 and Union Pacific 844. She looks best on bigger turning radius, but deals with the standart lego curve and switch. The built width is 7..8 studs. The loco is 54 long, and with the tender it's 83. The Big Ben Bricks' XL wheels fitted mostly for the desired scale. Some curiosity: The steam valve is a built in little pneumatic cylinder. PF cable used for pipeline imitation: The handrails on the boiler's two side made of the very old technic flex system's inner cable. Electric side: 2 PF train motor 1 PF L motor 1 PF IR receiver (v2) 1 PF battery box 1 PF extension cable (50cm) 1 PF polarity switch The tender contains all the PF elements, except the L motor and the extension cable. Two train motors are attached to one output of the IR receiver (of course, one of them with the polarity switch). The L motor is in the loco, connected to the other IR receiver out. That way, it's possibble to start the loco with full voltage, the big wheels slipping, and then turn on the main drivers in the tender. Some more pics: Hope You like it!
- 26 replies
- steam loco
- moc
(and 4 more)
Tagged with:
