Showing results for tags 'service truck'.
Lego 42008 Service Truck Thanks to EuroBricks for making this review possible! As I looked at the recent Technic sets, this was one that I thought looked interesting, but not enough to buy. So when the opportunity to review it came up, I jumped! It's a European-style heavy tow truck with pneumatics and motors, so that's pretty cool. And it's GREEN. It's a surprisingly uncommon Technic color. There's the 2015 24 Hour Race Car, but other than that and some of the small sets, this is it. So there should be lots of new part availability and so forth for people to geek out over. Let's see how it looks.... Name: Service Truck Set Number: 42008 Pieces: 1276 Price: $129.99 Minifigs: n/a Theme: Technic Year of Release: 2013 Links: Bricklink Peeron Brickset The Box A normal Technic box. Except for the exciting info in the bottom corners indicating that this set has BOTH Power Functions and pneumatics. That's pretty rare but very cool. The Back of the Box A lot more detail back here - both the main and B models are shown with their functions and sizes highlighted in a multitude of languages. With all the details I'm surprised that the HOG steering isn't identified anywhere. The main model does show that there IS steering, and most Technic fans see the gear on the cab roof and immediately know what that means, but I was surprised it isn't called out anywhere. As for the B model, instructions are online only, not printed, but that's normal. It seems to have a lot of functionality for a B model but is very similar to many other Technic sets with a claw arm and trailer. The Contents There are a TON of bags in here. Small ones with small parts, big ones with big parts, some PF parts, and a bag full of pneumatic stuff (including precut hoses, unlike old pneumatic sets). Oh, and 3 manuals and a sticker sheet in a bag together. No cardboard, but the books are enough to be reasonable protection for the stickers. Seriously though, SO. MANY. BAGS. The REALLY? The reason for so many bags? Not just the 1200+ parts, but also bags like this. There are TWO identical bags like this. Why on earth weren't they combined? I just don't get it. I'm sure there's something in Lego's packaging and logistics to explain it, but I don't see it. The Manuals Three thin books. Not much to say, other than this is a 2013 set so one book has that Win kid on the back. Eek. The Sorting Instructions So Lego obviously thinks you should sort the parts. Makes sense, since there are no numbered bags or anything like that. Just 1200 and some parts to look through. Being Technic, it's easier, since there's tons of black pins and blue axle pins and so forth, but there's still a lot to look through. However, sorting it right either needs a bunch of dedicated space, or a bunch of containers. I had neither, so I did this: The Part Sorting, Sort Of That's most of the parts, in the box. I kept them sort of sorted by size. There are a few things I left out - the wheels, big panels, pneumatic and PF parts, etc, but that's 90+% of the parts right there. Not TOO bad, and as long as you're careful, you can move the box around when you need to clean up for the night. It does how how oversize the box is though! The Stickers A BUNCH of stickers for this set. And they're not terribly useful for anything else. They're very specific to the tow truck, and they're mostly cut for the Technic panel shapes so they'd be weird on anything else. They do add a LOT of detail and color to the finished set though, so for once I will actually use them! The First Step The first actual page of the manual. I'm used to manuals having a picture of what you're making at the front - makes sense when it's a City set with multiple vehicles. Here? I just found it hilarious to see the finished truck there at step 1. The manual is standard Technic though - plain blue background, part callouts, and lots of sub-assemblies. The Build, 1 After a few pages, we have this. Anyone used to modern Technic can figure it out pretty quickly. This is the steering for the two front axles. As usual, it's some great engineering. The green beams under the arms of the second axle make the distance from the pivot point to the gear rack different, giving different turning radii to the axles. It may not be exactly right due to the limits of Lego parts, but the concept is certainly there and the functionality of the set is better due to it. The Build, 2 More pages, more pieces added. Again, any experienced Technic builders can recognize what's happening here. A vertical axle for the HOG steering, some frame at the front for a cab to be built off of, and some beams out the back to start building the body of the truck. And of course, a bunch of random-seeming pins and parts that'll be used for connections later. The Build, 3 Now things start getting interesting. This is the main gearbox. There's two red driving rings with then the dark grey gears to transmit the power to the light grey gears below. I'd bet money that the axle between the driving rings will be powered and there's gears coming that'll drive both axles from that simultaneously. And as an important note - the axles below (with the light grey gears) are NOT connected all the way through. The gap in the beams below the red driving rings is a gap in the axle as well, so there's 4 totally separate outputs on this gearbox. The Build, 4 This is now rotated and flipped from the last pic of the gearbox (note the axle with the universal joint in each photo). But I was right - the tan gears let the center axle drive both of the side axles with the driving rings. A motor will get connected in there and then we have 4 outputs, 2 of which could run at the same time. There's the axle with the universal joint, the black axle above the three tan ones (parallel to the u-joint), the back left output which gets redirected and ends up going to the dark grey 8 tooth gear in the top middle, and then the back right output which is not currently visible. The yellow connector sticking off to the right is a control handle to shift between two outputs, and there's a matching one on the right. All in all, a LOT of complexity in a small space! The Build, 5 That universal joint gets connected to another in order to take an off-center drive axle and connect it to a centered linear actuator. It also of course allows the LA to pivot. The Build, 6 The pneumatics appear! This grey cylinder is a pump. Turning the tan axle will rotate the short blue liftarms and power the pump. I'm sure this will connect into the gearbox for power, but there's a ways to go before we get there. The Build, 7 Actually, nope, I was wrong. That frame with the pump mounts right into the gearbox and onto the chassis. I've also added the winch, so now 3 of the 4 outputs from the gearbox are in use (large LA, pump, and winch). You can't see it, but the motor is also installed under the gearbox to drive it. The Build, 8 The 4th output of the gearbox drives these mini linear actuators. The drive is coming in on the gear closest to the camera and then the other 2 gears transfer power up to the far LA in sync. The Build, 9 Here's what those mini-LAs drive. A pair of spade-type outriggers. Since this is a heavy-duty tow truck that'll often need to pull loads out of ditches and so forth, these can dig into the ground for a lot of holding force. The Build, 10 Time to set the chassis aside for a while and build this. It's interesting how differently they can use identical pneumatic cylinders. The one in the black section can only swing the lower piece through a 90 degree angle. The one on top, despite a 2 stud stroke, manages to move the 15L beams a massive 9 stud distance thanks to the clever lever design using the 3x5 L beam and 5L beam. The Build, 11 So much added, so fast. The arm from the previous step attaches to the large LA to form the main crane arm of the truck. The pneumatic tubes all come together to a pair of valves to control those functions. Mechanically, the truck's pretty much done and there's still a book and a half to go in the instructions. That's a lot of bodywork to be added! The Build, 12 The bodywork starts with the cab. The battery box sticks in the usual Technic truck location behind the cab. Thankfully, it gets a sticker with green and red arrows that will help with knowing direction for functions later. The seats are black and grey instead of the blue that they often are. This is also an unusual case of a bare connection that ends up in a finished model. See the pin sticking forward between the seats? It's one of these used to stabilize the vertical axle that will be the steering. Only the pin on one side is needed, but this piece () wasn't available yet. The Build, 13 And that takes care of the cab. A few stickers here, but there's lots left on the sheet. Susanne gets a nice license plate too. It almost actually feels bland though. Especially once the rest of the truck is done and stickered, it feels like there should be more detail on each side of the grill here. And the black tubes for the sides of the windshield are a cheat. They don't line up vertically - the bottom is a stud farther forward than the top, so it needs to be something angled. It makes sense, most windshields ARE angled, but where many Technic vehicles would use axles there, there's no easy way to modify the bottom to put a connector for an axle instead (the top could take an axle though). That's why it's tubes - they have enough flex to do it. As for functionality, the doors open. That's about it. There's enough going on in the back of the truck I can forgive it though. The Build, 14 Here is one of the side panels. The other side is just a mirror image. It's a nice decorative panel, but why didn't they put one more of the small triangular panels above the "service" to smooth out the slope some more? Anyway, once you put these two side panels on and add the wheels, it's all done. The Side Comparison The side panels REALLY add a lot to this design, so I wanted to show exactly how much "mess" they're hiding. All the mechanicals of the bare truck are so cluttered by necessity, where the panel just smooths everything out and makes it look less Lego. I like the finished look. And since each panel is held on by just 3 pins, they're easy to remove to get to the battery box or fiddle with the internals. The Good Here's everything in the "deployed" position. You'd never actually use them all at once, but here it is. The crane arm has a decent amount of height, considering it's usage on a tow truck, and the extension on it works well enough. It's also good that the main boom uses an LA rather then pneumatics so you have height control. Full up there would be WAY too high for the wheel lift! Now that we have tires on, check out the front steering. Nice engineering making the dual steered axles do different angles like that. It's not something we see on real trucks here in the USA since the dual-front axle design is not common, but it's nice to see implemented. The Bad There are several small things that annoy me (and those of you with OCD will feel the same I'm sure) so let me point a few out. Each side of the truck has a flip-up panel with one of the gear shift levers underneath. There's a sticker to indicate functions, but due to the design of the truck, the sticker isn't centered over the lever. What? Look at the hoses coming off the small pneumatic cylinder on the hoist. They get in the way of the wheel lift coming up all the way. I'm not sure why they didn't design it with those hoses coming off the other side of the cylinder - I might have to mod it and see if there's a reason I'm not seeing now. There also is no good place to put the hook. As I played around with the truck, it kept snagging on other parts as they moved. The outriggers only come just to the table surface. They don't extend far enough to actually dig into the ground if you had it on dirt. but that's probably ok. They're nice looking but a little flimsy, so if they extended further, since most kids will use this on a hard surface, they'd try to lift the back end of the truck and fail. Access to the battery box switch is fairly tight. It looks roomy enough, but as a 6'3" guy with man-hands, it's tight getting my fingers in there to control it. Too bad they didn't use the PF switch and put it somewhere more accessible. The Video Note when I show the pneumatics at the end, there's an issue with the pump. Since there's very little tubing and no air tank, it builds up to max pressure very quickly. That leads to a loud clicking sound when the pump is running, since it's being forced to compress with no room for the air to go, and then the pump slams back open as soon as the gear turns a bit further. It's loud and annoying. Once you start using the functions, it quiets down, but then gets loud again a few seconds later. The Conclusion So, what's my conclusion on this set? Pretty cool! This was one of a series of service trucks in a short span - 2012 had the Pick-Up Tow Truck, and 2011 had a Flatbed Tow Truck - but you have to go back to 2006's famous 8285 Tow Truck to get a more direct comparison. I've built the 8285 and it's an awesome truck, but different in many ways than this one. 8285 is much larger and has a bigger piece count, so everything is bigger. However, that leads to a lot of empty space in the truck. There's not many Technic vehicles made that have as much empty room in them as the 8285. Also, 8285 had no motor, so you had to pump the pneumatics by hand. This one is much nicer in that regard. Overall, I like it better. For a non-flagship set, this packs a TON of features. The Ratings Value: 10/10 - It's so close to the famous 10 cents a part mark, and there's so many useful parts. Lots of panels, PF, pneumatics, so it's solid. Design: 8/10 - As a whole, great, but there's a few details that could be improved. Minifigs: n/a - Playability: 9/10 - Lots of functions, and it's in a common Technic scale so I bet it would work well for towing other vehicles around. It'd be better for smaller fingers than mine though. Parts: 10/10 - It's got both pneumatics and PF, plus if you want green Technic, it's the only place to go. It's the only source of 1x7 beams, the best source for 1x9 and 1x13 beams, and the only current(ish) source for green panels. Overall: 9/10 - Very solid.
Lego 42008 Service Truck (B-Model) Thanks to EuroBricks for making this review possible! As I looked at the recent Technic sets, this was one that I thought looked interesting, but not enough to buy. So when the opportunity to review it came up, I jumped! The main model is a European-style heavy tow truck with pneumatics and motors, so that's pretty cool. But what about the B-model? It's a claw truck with a trailer. We've seen similar models from Lego before (we had the 9397 Logging Truck [though no trailer on that one], 8049 Tractor with Trailer, and we could stretch to the 8110 Unimog and 8258 Crane Truck as well). So how does this compare, since it's a B Model? (If you'd like to see my review of the main model, it's right over here) Name: Service Truck Set Number: 42008 Pieces: 1276 Price: $129.99 Minifigs: n/a Theme: Technic Year of Release: 2013 Links: Bricklink Peeron Brickset The Back of the Box The back of the box shows the B model for us. The instructions are online only, not printed, but that's normal. It seems to have a lot of functionality for a B model but is very similar to many other Technic sets with a claw arm and trailer. The Build, 1 Following the instructions on screen (not my preferred way to build, although at least the quality was decent on this set) we get the frame of the truck to start. The Build, 2 Now the back wall of the cab is partially installed, as well as most of the steering system in place. It's simpler than the main model, since there's only 1 steered axle this time. You can also see some of the weird design bits due to it being a B model, such as the exposed pin on the connector being used to brace the right angle in the steering. You can't see it, but actually BOTH pins of that connector are unused. The Build, 3 The cab's made a lot of progress. You can see a few more oddities, like the white license plate stickered beam that's mostly hidden. I probably should have turned it around, but oh well. (the manual doesn't show stickers on the B model). (and yes, I hadn't found one of the grey grill pieces, but I was tired of digging through the parts. I found it later and put it on) The Build, 4 Now the cab is done. It's ok. Not great, but ok. There's weird color things going on due to the part limitations, and the doors feel too recessed, and the "winch" on the front is just an excuse to use those pieces up. (and yes, I did it backwards in this photo. The cable should hang down the inside rather than the outside to make the ratchet work correctly) The Build, 5 The chassis has also been extended backwards. The rear axles are visible, as are the starting points for the crane, rear stabilizers, and lots of other pins waiting to be built upon. The Build, 6 Time for a gearbox. Looks like we'll have the central input shaft going to 3 outputs. The Build, 7 The gearbox slips into the frame and we get to connect up the outputs. As in the main model, we have a powered air compressor (the black and grey cylinder right in the center) plus, so far, an output going back through a couple u-joints to that vertical crane connection we saw in the last photo. The third output hasn't been used yet. The Build, 8 A whole layer has been added to the back of the truck. The third output from the gearbox now runs back to the outriggers. The colors all seem haphazard. It's understandable, but does make it obvious this wasn't the main model. The Build, 9 Those "wings" sticking out behind the cab turned out to be the battery mounts. Simple and effective, and it's unusual to see a horizontal battery box behind the cab like that. Also unusual, there's that mini-LA at an angle to rotate the crane. Lego has used linear methods (LAs or pneumatics) to rotate things before, but it's unusual. Since the main model didn't have a turntable, this is an alternate way of making a "powered" swiveling base. The Build, 10 That's a very unusual boom setup there. And seriously, an axle with a bush on it as a manual control for rotation? The whole setup is just weird and slapdash. I hope it at least works well... The Truck, Finished Here's the final truck. It functions, but it's got some issues. The pneumatic hoses are too stiff and since they come horizontally across the red beam, they keep the claw from hanging as freely as it should. And again, the controls are awkward. There's the manual rotation control on the left, the pneumatic control on top, and the gearbox controls on both sides. Too many levers in too many places. The the rear outriggers... they're there, but barely. The Truck, Reaching Out Here's the full reach of the crane. It'll reach the ground barely, and can rotate to the sides. It's not really enough to reach into the trailer though, if the trailer is connected behind the truck. To do any work, you need to park the truck between the load and the trailer. There are a bunch of beams left over you could use as a load, but the claw doesn't grab them very well. The Build, 11 Time for the trailer. A basic frame to start - axles for the single set of wheels, a "hitch" up front, and a manual leg that can come down. The Build, 12 Here's the start of the tipping setup. That is a weird linkage from the mini-LA to make the trailer tip sideways. And again, a bush as a knob to manually control it. The Trailer, Finished The previous frame mounts to the trailer and a bunch of panels fill out the trailer. Too bad there's random stickers all over. Guess it gives it a "distressed" look? The Trailer, Tipped That's as far as it tips, but it's enough to get the job done. The Conclusion So, what's my conclusion on this model? It's meh. The build is ok, the functions are ok, but the final thing feels definitely B and not main model material. The colors are random, the stickers are in the way, and the functions just feel haphazard.I'd recommend building it first so there's no stickers and you can see it for a day or two, and then take it apart and build the main model and leave that one built. It's much better than the B. The Ratings Value: 10/10 - It's so close to the famous 10 cents a part mark, and there's so many useful parts. Lots of panels, PF, pneumatics, so it's solid. Design: 4/10 - Haphazard colors, stickers from the main model, etc. Minifigs: n/a - Playability: 6/10 - It's got some functionality, but the controls are awkward and it doesn't actually pick things up well. The reach of the boom is short as well. Parts: 10/10 - It's got both pneumatics and PF, plus if you want green Technic, it's the only place to go. It's the only source of 1x7 beams, the best source for 1x9 and 1x13 beams, and the only current(ish) source for green panels. Overall: 5/10 - Ok to make once, but then build the main model since it's much better.
- 5 replies
- 42008
- service truck
- (and 4 more)
