Showing results for tags 'russian atv'.
Hey, Eurobricks! It’s been a long time. And for me it’s been a really tough time. Actually I’ve been suffering from anxiety disorder and OCD for a long time. It seems I can just handle it and not let it affect my life (which I did also for a long time) but things got out of control in the past few months. It’s the darkest time in my life and basically I lost interest in doing anything. God knows what I’ve been through. Luckily I got my family with me all the time. More importantly I didn’t do anything bad & stupid to myself. It is still a recovery process for me, but I think I’m well enough to pick up some unfinished LEGO projects, something I love to do, and something that will make me feel better. So today, I’m bringing you one of those projects - a LEGO version of the SHERP ATV. Parts count: 1374 pcs Weight: 1420 g Dimensions (Length x Width x Height): 232 mm x 195 mm x 178 mm / 9.13 in. x 7.68 in. x 7 in. Exterior I like this kind of compact vehicle, especially with massive tires. While building this model, I have a single goal for the exterior: full enclosure. It all started with the mudguard. I tried to use Technic parts to build the middle section but it’s nearly impossible to recreate the curves with no gaps. So sloped bricks become the best choice. To compensate a little bit on the extra “unnecessary” weight, the enclosure is also used as part of the gear housing. Drivetrain Instead of putting two identical motors on each side and making it skid-steer drive, I decided to make a drivetrain based on a subtractor. It made precise steering possible, and can be controlled one-handedly by Sbrick, which something I prefer when I drive the model while holding the camera on the other hand. This is a prototype: It’s a failed attempt. Knob wheels not only cause unsmooth power transmission, but also take the space of a 5x7 frame, which is supposed to be a sturdy housing for the lower differential. As a result, the lower diff got damaged from gear slipping after 5 minutes of test drive, the whole model couldn’t move completely. After several tests, I replace the knob wheels with 16-tooth clutch gears. it only introduces very little frictions and it’s very reliable. Here is the final version: Performance I made a short video (4K): More Details Hope you like it. Feels good to be back
- 41 replies
- sherp
- russian atv
(and 1 more)
Tagged with:
