Showing results for tags 'rc buggy motor'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 2 results
  1. Hello Guys, Today I would like to present my first moc here, which was built for the Buwizz fast car competition. I have been back to Lego for about 2 years now. I have built a few Mocs, and mods, but I have not found them good enough to show to others. :) I hope you like this little buggy, let me give you some more information about the build. I was half way with a build when I heard about the competition, so I decided to change that according to the rules. I usually build with more motors, so the challenge for me was to make the model efficient. I started with a 4wd version, with differential on both axles. The main feature was the independent suspension with small pneumatic pistons as shock absorbers. I started to test this solution on Agrofs buggy modded by Kbalage. It worked well, so I decided to use this solution in this build to help the stability of the car after the jump. As you see, I had to give up the 4wd setup, as the single rc buggy motor even with Buwizz 2.0 was just not enough to do the job. I have some pictures of the old version, and I have a plan to put 2 motors in it, will post that, once its built. So I decided to reduce the friction by eliminating all the gearing, so the rear wheels are propelled from fast output. I hope you will like it Guys, let me know what you think. :) An earlier version with 4WD: At the very beginning: Suspension test: Here is the final video: A few photos:
  2. Hi everyone, I ask for help with a problem with the PF connectors of an RC motor (Chinese version of course). As shown by the photos, after a few minutes of use on the Rally Car 42077 powered by Buwizz in ludicrous mode, the plastic swelled and "melted". This resulted in a bad or impossible connection with the extension wire it was connected to. I also had a hard time disconnecting the motor connector from the extension cable connector as they were almost stuck together. Has anyone encountered similar problems? Should I definitely give up on ludicrous mode when using this engine? Would I risk melting the plastic of the Buwizz if I attacked the Rc Motor directly?
