Showing results for tags 'new holland'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 3 results
  1. Ever since Lego released the 42054 set, I've been waiting for a smaller size agricultural tire to be able to build a medium-sized tractor. Unfortunately, there are no smaller agriculture tires, but I decided to build a medium size tractor :) New Holland TM 140: The model was built to create instructions. Knowing this, I've created a compact chassis that I can use in the future. The tractor has a drive with a Large motor with gear ratio 1:7 and steering using a servomotor. Three-point hitch systems are raising by the medium's engine . The front one can be detached. In addition, the power shaft drives the medium motor (gear ratio 1:3). The model has 4 functions so it is controlled by sbrick I had to limit the amount of details so that everyone can easily build such a model after buying the instructions. The original fits very well with building from bricks. I am very happy with how it looks because it's hard to know that it's a LEGO model. The instructions have been created for me by M_Longer Creations. Thanks Marek! Parts list in Rebrickable, Bricklink XML, Brickstore and png versions can be found here: https://bricksafe.com/pages/M_longer/misc/nh140 Instructions can be bought at Sellfy and Rebrickable: https://sellfy.com/m1longer https://rebrickable.com/users/M_longer/mocs/ Claas Quadrant 2200RC I did not want to build only a tractor. I decided that I would build a straw baler. I chose the Claas Quadrant 2200 RC. It seemed to me that it would be possible to copy it very well in bricks. The original machine has very many curves. In the end, I managed to build everything and put a lot of details. An additional function is moving the straw bales and the next ones can be put on the top of the machine. More photos: Video: Thank you for reading and all the comments! :)
  2. Only one model today :D For a long time I wanted to build a classic agricultural trailer. It was supposed to be a standard double axle version. However, when I built the New Holland and Fendt tractors, I changed my mind and decided to build a tandem trailer. I made such a decision for a simple reason. The only output that can be controlled in tractors is the PTO shaft. This version of the trailer does not have to have a pneumatic system or engine to raise the kiper. In addition, the model had to be in a popular color because I wanted to create an instruction for it. The choice fell on Krampe Big Body 550. Trailer frame The frame is a fairly simple liftarm structure. The first version had a pendular suspension, but I had to remove it because the loaded trailer was unstable. Thanks to this, I could additionally strengthen the frame and move the cylinder towards the hitch in order to increase the load capacity. At the moment, it is about 1 kilogram Tipper I wanted to build a realistic model. Because of that I had to give up technic panels. If I used them, the tipper would weigh 1/3 of its current weight. Bricks are heavy, so the payload has dropped. The model looks very good like model–team one. I am glad that I managed to reproduce the curvature of the sides. The tailgate lifts automatically when the tipper is lifting. The trailer has a system of pull rods that lift it up. If the tractor has a pneumatic system, it can be replace by lego pnaumatic cylinders as a separate function Thanks for reading! Build instructions can be found here: https://rebrickable.com/mocs/MOC-26566/M_longer/krampe-550-tipper-trailer/ VIDEO:
  3. I'm planning to build a series of tractor mocs and here is the 7th of them: Case IH Magnum Rowtrac Index: Case IH Magnum Rowtrac Case ih magnum Massey Ferguson 7480 CLAAS Axion 900 CLAAS Axion Terra Trac New Holland T7 HD Steyr Terrus #1 CLAAS Axion 900 Features: Pivoted solid front axle HOG steering Adjustable front hitch Adjustable rear hitch Rear PTO connected directly with rear differential Modular design: chassis, rear hitch, cabin are built separately So no front PTO nor 4 wheel drive due to its small size, sorry guys... Instructions are at: https://rebrickable.com/mocs/MOC-129921/ Video introduction: Some comparison photos with a Siku model: A little closer look at it: Exploded view: Hope you like it! Thanks for watching.
