Showing results for tags 'case ih'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 4 results
  1. Hello, since my somehow succesfull moc the Challenger MT965E i decided to build more, and now in form of familiar Case ih tractor, i already builded bare chassis, this time i switched to servo operated steering instead of linear acctuators, videos of progress are here, if you have any ideas and recomendations, ill welcome them :) Current form PART 1 PART 2
  2. Currently I'm bulding a Lego version of the Case Quadtrac 620 in 1:16. It's mainly built in Studio, but tested several mechanism to make sure things are working as expected. Haven't assembled everything yet, exept the tracks and an early version of the rear frame. I'll likely build it after i finished organising my lego parts (haven't done that for years). Here you can find some early sketches from 2008. Since then (and after a long dark age) quite a lot has changed. Even during the last couple of weeks. For a quick impression, this is the current state: Here you can see some more rendered images and screenshots. My goal is to get as close as possible to the original. That includes function, geometry and look. Planned and partially done is the following: Remote controlled with two SBricks and powered by Legos rechargeable battery box Driven by one or two large motors (hard coupled), speed should match 1:16 of the original max speed (40km/h) Steering done with two small actuators and controlled with one large motor (mainly because of the many pin holes for connecting it to the frame) Suspended cabin Front light Openable bonnet Authentic connection between front and rear unit, means no turn table Oscillation between rear and front unit PTO driven by one medium motor located in the front unit 3-point hitch lifted by two small pneumatic Motorized compressor (Mini Motor 71427, located in the rear unit ) for 3-point hitch Motorized switch (medium motor, located in the rear unit) for 3-point hitch Realistically oscillating tracks Spring-supported track tensioner Suspended rollers (these three rollers in the middle) Optional: Full lightning like the original Optional: Maybe a gearbox, but I'm afraid there will be no space left One of the challenges is to fit everything inside the frame, which is 9 studs wide. That leaves 7 studs. Questions, comments and criticism are more than welcome.
  3. Hello everybody. Here's my WIP moc of Case IH Magnum 340 CVX. Controlled by Control+ More photos soon, currently testing.
  4. I'm planning to build a series of tractor mocs and here is the 7th of them: Case IH Magnum Rowtrac Index: Case IH Magnum Rowtrac Case ih magnum Massey Ferguson 7480 CLAAS Axion 900 CLAAS Axion Terra Trac New Holland T7 HD Steyr Terrus #1 CLAAS Axion 900 Features: Pivoted solid front axle HOG steering Adjustable front hitch Adjustable rear hitch Rear PTO connected directly with rear differential Modular design: chassis, rear hitch, cabin are built separately So no front PTO nor 4 wheel drive due to its small size, sorry guys... Instructions are at: https://rebrickable.com/mocs/MOC-129921/ Video introduction: Some comparison photos with a Siku model: A little closer look at it: Exploded view: Hope you like it! Thanks for watching.
