Showing results for tags 'mars base'.
This is my entry for the Lego Ideas "Moon to Mars" contest https://ideas.lego.com/challenges/a289cd61-c960-4364-a1a8-42da645a4fe6/application/ff3e793f-c099-4c20-aef0-4612f4e53ab8 Caronte, a spaceship assembled in orbit around Moon to transport a crew to Mars and provides all necessary to create the first ground base on the red planet.. Caronte by Rusty B. I used a "capsule" design, with a pair of dome on each living module to have a good light source.. in the middle of the ship there is a working rotating system usefull to create the artificial gravity on the floor of the living modules. During the journey, the crew can live inside them easly.. Caronte by Rusty B. The spaceship is mdular, because when arrives near Mars, the modules will be undocked from the ship main structure and will be send on the planet landing on the surface using parachutes... Caronte by Rusty B. The crew lands on surface inside the Command pod / Rover and assembles the landed modules to create the ground base.. there are also two containers with inside solar panels, connection wires, a accumulation battery, a parabolic dish antenna and the rover wheels, that will be mounted on the Command pod to trasform it in a rover.. Caronte by Rusty B. The command pod / Rover has a command seat to drive the spaceship/rover, a second seat with computer and a back space to transport things.. Caronte by Rusty B. The base itself is playable with the opening roofs, to let play inside with the crew minifigures.. list of modules: - Airlock: Caronte by Rusty B. The Airlock helps the crew to enter and exit the base, balancing the internal atmosphere and contains the spacesuits for the external surface walk.. - Crew living module: Caronte by Rusty B. The main living module, with beds for crew, lamps on them, a recreation computer and space to keep personal objects.. - Science module: Caronte by Rusty B. In this living module the crew works, making experiments with Mars rocks, analyzing the scansions made with rover... there are a main desk with a laptop and microscope, rotating seat, a space with lab instrumentations, a drill to analyze rocks, and the infirmary, with all need to heal the crew.. - Greenhouse module: Caronte by Rusty B. This living module provides the food for the sustenance of the crew, during the space travel and on the ground... with a mix of traditional and idroponic colture, the plants grow and produces vegetables and fruits.. - Cargo bay: Caronte by Rusty B. In this container there are all the equipments to make the ground base operative.. directional solar panels, a accumulation battery, wires to connect the panels to the battery to the base itself, and a parabolic dish antenna for the communication between the base and the control base on the Moon or the Earth.. - Wheels bay: Caronte by Rusty B. To transform the Command pod in a rover, this container has inside four deassembled wheels... for more pics, visit my Flickr https://www.flickr.com/photos/152734688@N06/ because in the renders the trasparent domes are too dark, i've removed them in some pics to let see easly the internal... I used only existing parts in existing color... but probably i've made some mistakes... i will re-check all the colors, and if i will find some errors, they can be resolved easly without changing any shape particular or details... What do you think? As always, comments, opinions, suggestions and costructive critics are really welcome!
