Showing results for tags 'lego spaceship'.
Introducing a new Lego Classic Space Spaceship - Aquarius, which is a Wanderer Class Planet Hopper, Mark I, which was inspired by the Scorpio from Blake's 7, hence the name Aquarius, the spaceship is a combined cargo carrier and explorer spaceship. The Lego Classic Spaceship is 3 ft long, 15 inches wide and 10 inches tall and I estimate between 3000 and 4000 pieces were used. The Lego Classic Spaceship has a ramp at the back which folds up and unfolds when the spaceship lands on a planet or a suitable surface, there are two sections of the spaceship roof which can be removed revealing the cargo bay and light drive engine mechanism and the flight deck, which is connected to the cargo bay by a sliding door. There are rear doors leading out to the ramp, the legs are permanent feature of the spaceship as they have rockets which are powerful enough to lift the spaceship of a surface before the spaceship flies away using the Light Drive Engines. The Light Grey, Light Bluish Grey and Trans dishes on the roof are the sensor relay network, the three trans orange aerials are the communications array, the gray object which looks like a gun is the radar system, the various grill and round bricks on top are the exhaust ports. The trans yellow aerials are laser, the ship has two on the front and six midway next to the missile launchers, the round brick structures with yellow and black lines are missiles ready to be fired. --------------------------------------------------------------------------------- The below image is of the right front of the spaceship. The below image is of left front of the spaceship. The below image is of the front of the spaceship. The below image is of the left back of the spaceship. The below image is of the right back of the spaceship. The below image is of the back of the spaceship. The below image is of the top with the rear removable section removed revealing the Cargo bay and the two Light Drive Mechanism which are fenced off from the rest of the cargo bay, the three vehicles are parked ready for a missions or tasks the crew may have. The below image is of the top with the front removable section removed revealing the flight deck with 7 Lego Classic Space Minifigures, and two custom Lego robots. the flight deck is connected to the cargo bay via a sliding door which in flight would be closed and sealed with the flight deck being pressurized. The below image is of the rear showing the rear doors open, the ramp lowered and unfolded, the Light Drive Engines and the three explorer vehicles. The below image is of the rear removable section showing the various lights, the communications relay, two sensors (part of the sensor array of the spaceship), the vents. The below image is of the front removable section showing four dishes (part of the sensor array), the radar, the various lights, and the exhausts. The below image is of the right side of the spaceship, showing the landing legs, the four lasers, the missile which is ready to be launched and the rear engine room. The below image is of the rear of the spaceship, showing the ramp folded up as if in flight or getting ready to take off. The b The below image is of the left side of the spaceship, showing the landing legs, the four lasers, the missile which is ready to be launched and the rear engine room. The below image is of the front of the spaceship, showing the six lasers and the two missile launchers with missiles ready to be launched and the three landing legs. The model took one and halve weeks to build and 2 weeks to sort the parts I needed.
- 4 replies
- space
- lego classic space
- (and 6 more)
