Showing results for tags 'intercity bus'.
Hi, I am mostly active in Technic section (RC 4x4, 6x6), but I decided to make a flashback, and return to old school Lego building. I tried to build a 2000's intercity bus by using both some 1970's parts as well as newer ones. The bus below is fictious and do not represent any brand. Just what is on my mind came out as V 1.2 (second version), so I want to call it Intercity V 1.2 I have still some discolored parts to be replaced: Front view: Rear view: Right side: Left (driver's) side: An air conditioning unit is added on the roof: Bottom view, fake engine is visible at the back: Articulation movement is added to the rear axle to ensure the rear axle is always on the ground: Full interior design is added with 2+1 seating: Front axle has 1970's style bogie type steering (similar to the steering system used in Fageol Cargoliner): The fake opening parts are determined mostly by using separator lines, front door: Mid door and luggage compartments: Mirrors are added: Overall: All the best
- 14 replies
- intercity bus
- 6 stud wide
(and 3 more)
Tagged with:
