Showing results for tags 'electric locomotive'.
Hi all, Being a steel and mining industry aficionado anyway, this year’s OcTRAINber contest struck a chord. So I chose to design a 1/33 gauge 1 model of a coke quenching locomotive. A… what???? Please bear with me if I’m not going to explain the industrial cokery process here; it’s too complicated to do this in a foreign language. Anyway, the thing is: There are special locomotives for that process. They are usually very small, electric, and typically characterized by a bizarrely elevated cab and lateral pantographs. Here’s a drawing of the prototype I chose, a locomotive that was built by Jung in 1927 for the „Zeche Sachsen“ colliery in Heessen (now part of Hamm) in Germany: You’ll immediately recognize the main problem: The engine is extremely narrow and, as if this wasn’t enough, has an outer frame covering the wheels. In 1/33 scale, the frame and locomotive body have to be 8 studs wide, while the outer edges of the wheels already are 7 studs apart… that gave me some serious headache. But finally I found a solution. Here’s what the digital sketch looks like at the moment: Rather sparse interior – after all, all the engine has to do is to shuffle back and forth on a single straight track… The model is fully motorized with a PF M-motor, a BuWizz (only a brick-built dummy in the picture) and a worm gear for slooooooooow shunting: Now I’ll have to gather parts, start building and hope that I’ll be able to finish until November 15th… Thanks for stopping by! Sven
- 45 replies
