Showing results for tags 'eldar clan'.
*Your entry has earned 8 XP* Ch.1 Mando's On The Hunt It was a simple bounty puck. Just another bail jumper hiding out on Arcan IV, or so Var had suspected. Turns out the bounty had been dealing with an empire cell and Var had just interrupted their secret meeting. Before he knew it, Var was neck deep against an army of stormtroopers. "Drop the blaster. It’s over, we have you surrounded", the stormtrooper shouted. "I’m not so sure about that", Var replied as he reached over to his belt and quickly grabbed a thermal detonator. He knew he would not be able to escape the explosion but Var had no other choice. He resigned himself when suddenly blaster shots came firing from the rear. They all look up to the sight of another mandalorian swooping in from behind, completely catching the stormtroopers off guard. Var sees his opportunity. One mandalorian is enough to turn the tide, but two mandalorians and the battle is won. ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Hey guys, I decided to expand my prior build now that I have re-familiarized myself with my bricks. I wanted to go for a more industrial, rusted look. Tell me what you guys think. Also I would like to make this my official submission to the Mandalorian challenge. Edit: I have swapped out the original photo with an improved one, so you should be able to see the build much better now.
