Showing results for tags 'e-2'.
Hi all and Happy New Year!!! Since I'm waiting for H0 parts to arrive to continue my experiments, I am browsing the Internet a lot to get some inspiration. Searching for some American locomotives I found (again) the Bipolar, a locomotive which I like a lot...but I always end forgetting its name. I recall the GG1 in my mind...but the name Bipolar name simple does not fit into my 64kb of memory (38911 bytes free)! So, I thought it could be nice to try this big lady in 12v, just for fun. In this case, I built the E-2, the lattest rebuild of one of the Bipolar family, made in 1953. It's a massive thing, and the two motors will surely be helpful to move the locomotive and the Hiawatha train (I did not design the wagons, but for sure they would be...heavy!!!). As the original E2, the locomotive has asymmetric details on the two "big noses". The colors are WRONG - yellow should be orange, black should be dark gray, so I kept a 7740 paint scheme, well suited to the color range available in the 80s. As any high-end locomotive it has some expensive parts (all the windows). One note - the 2x2 windows can be also in old gray (from 7740), a bit cheaper option. The locomotive has 6 point of articulation, I think it could manage the R40 curves - my real life DB BR78 is less articulated, just to made an example. As you can see, the whole body seems a bit taller than normal 12v trains, but all in all, the real bigger details are the two pantographs. I don't think I'll ever build it in real bricks - for the only reason that I'm not so convinced to see it going around R40 curves. Maybe it could be a good shelf queen I hope you like this one! Ciao! Davide
