Showing results for tags 'display case'.
I got tired of dusting and trying to keep my Lego Carousel Clean from Dust and Cat Hair and other things that could get to it. I like to display it but wanted to protect it as well as being able to see it. I could not find a Display case that was big enough or the right size so decided to just build my own. I started by buying some Lexan at my local hardware store: 3M makes a great Lexan product. I also used some caulking that is made just for Lexan: then I cut out the material using a table saw and a fine toothed blade, I kept the protective coating on the Lexan because it keeps the material from splintering and also scratching as you move it across the table saw. I taped it together on all the sides taking one piece at a time untill I had a complete box: Note before I cut out the pieces I measured my Carosel and made sure I added a little extra so there was plenty of room to display it in the box. Once it was taped together I then started caulking the joints togheter cutting the sealent opening at an angle and running the caulk so it would get in the cracks but come out in a smooth line. I let it dry for 12 hours then it was safe to remove the tape: Removing all the tape: I then let it dry for 12 more hours to make sure it was solid then I cleaned it with a miled glass cleaner (no Ammonia) and put it over my Carousel SWG
A little gift for Speed Champion owners: a stud.io custom part of a "known competitor brand" (I wonder why TLG does not make them) Display Case for Speed Champions series. Being an owner of a certain number of these sets, I had a "dust problem" and found an elegant solution by using them (not an advert of an undesired 'brand', I do not publish the vendor name) and they work amazingly. For those who may use them and would have their digital model for Stud.io, I made it as a pair of custom parts: bottom-base and shell-case. Custom part: https://bricksafe.com/files/Void_s/speed-champions/ClearCase.part Studio model: https://bricksafe.com/files/Void_s/speed-champions/ClearCase.io
