Showing results for tags 'digitl designer tubing'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Hi, I am making train rails in Ldd by using flex cables, pin connectors and lamp holders, The tubing goes through the hole in the lamp holder, and pins connecting the pin connector sleeves however since I need corners and at a range if different angles for more realistic layouts I need to be able to flex the flex cable to a curve like this one. This means having it so it is curved 'perfectly' meaning there is no S shapes, even slight ones, and also means that if you cut it in half the curvature should match up, once I know how I can do this I can actually start building descent track, the tubing should not be sloped up or down though with this same possible technique provided it will make this possible for when I want to use sloped track and even track terminals (to switch tracks). Note that the two tubes will be joined together to make one section of straight or curved track, if this is too hard to do, you can use a longer flex tube if you want.
