Showing results for tags 'cr-90'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Alternative Brick Brands
    • The Alternative Brick Forum
    • CaDA
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Ten years after building a first version of an UCS-like Tantive IV, inspired by official sets 10019 and 10198, I have decided that it was about time to provide some lifting to my MOC. Believe me, coming back to an old MOC is a challenge. Over 10 years, many new parts have been released, many new build techniques were introduced and if means what can be seen as a simple re-lifting may become a total rebuild. Anyway, without additional blabla, here is the result: Tantive IV - 2023 Edition by Veynom, on Flickr And you may compare it with my previous edition from 2013: CR90 Corvette Tantive IV by Veynom, on Flickr Just as the previous version, it can be opened to reveal a detailed interior: Tantive IV - 2023 Edition by Veynom, on Flickr Instead of letting you spot the 7 differences (and there are more than 7), I will review the main changes brought to the model. The first one is about the color scheme. The old dark gray and red have been replaced by DBG and dark red everywhere. The model is also globally whiter than the 2013 version. The second global change is a massive move from studfull to almost studless, only keeping studs were it could provide greebling advantageously. And now, let's start to zoom on some sections, starting with the rear engine section. Tantive IV - 2023 Edition by Veynom, on Flickr It is 6-stud wider than the original, with extra space added between each engine pod in order to add some extra details. Just making it wider implied a full rebuild from scratch. Many, many details were added everywhere to closely match the original model. The engines are a bit longer and the exhaust part was revisited to provide a nicer visual effect. Just detailling the exhausts added more than 400 extra parts to te model. Tantive IV - 2023 Edition by Veynom, on Flickr With the radar section, I made structural strengthening, extra details on the lateral pods with smoother ending, detailed inside, brick-build white wings, and a brick-build radar. Tantive IV - 2023 Edition by Veynom, on Flickr The roof section was also rebuild from scratch. Details were added to all panels for visual improvement and also to ensure minimal holes between angled panels. Then we have the head... Tantive IV - 2023 Edition by Veynom, on Flickr I cut the head just after the central section and rebuilt it completely. As the original shape is somewhere halfway between a hammerhead and a double truncated cone, just reproducing it is already a challenge. If you further want it hollow in order to add a detailed cockpit then it becomes a very interesting challenge. The solution I used is maybe not the most esteatic one when looking at it closely but it does the job when moving a bit away from the ship and it allows to put 4 sitting minifigs and some walking ones in the central corridor. Tantive IV - 2023 Edition by Veynom, on Flickr It was really not easy to capture the curves, the outside details and still proposing an easy way to open it. Yet, the result is quite strong with enough details inside. Tantive IV - 2023 Edition by Veynom, on Flickr And there is a corridor allowing us to guess about some well know scenery from ANH. Tantive IV - 2023 Edition by Veynom, on Flickr And now the main room. Tantive IV - 2023 Edition by Veynom, on Flickr With Darth Vader, always elevating people around him with his typical sense of Imperial justice. Tantive IV - 2023 Edition by Veynom, on Flickr My lateral pods are still present, each with a small vignette inside and more details or better smoothing. Tantive IV - 2023 Edition by Veynom, on Flickr Tantive IV - 2023 Edition by Veynom, on Flickr A few more pictures from the build: Tantive IV uplifting WIP by Veynom, on Flickr Tantive IV uplifting WIP by Veynom, on Flickr TantiveIV uplifting WIP by Veynom, on Flickr A friend of mine told me the radar metabrick was not up to the level of the MOC. So I built a new one ... the result if indeed much more appealing and aligned with the original model. TantiveIV uplifting final WIP by Veynom, on Flickr A color swap which truely improve the visual impact: replacing the LBG engines (wheels) by dark pearl gray ones. Tantive IV uplifting Engine colors by Veynom, on Flickr Now, there is still a major disadvantage to this re-lifting. The beast weights now 25% more than before, increasing from 4.4 to 5.5 kg. Heavy MOC, I tell you. The length remained identically (that was a surprise to me). I've no clue if I will change it again in 10 years, maybe it will switch to a blue color-scheme...
