Showing results for tags 'building report'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Hello everyone, a few days ago I received my test copy of the Science Tower. A bit later I also got the first version of the building instructions, which needed to be tried and tested. On this occasion I’d like to show you a short building report, maybe it’s interesting for one or another. The Science Tower is my contribution to the BrickLink AFOL Designer Program, some have probably already heard about it. More information about the set and more pictures can be found here: https://www.bricklink.com/v3/crowdfunding/designer-sets-for-adult-fans-of-lego/59446/Science-Tower Before the assembly came the dismantling of the finished test model, after which about 1200 parts lay on the table: In addition to some standard colors Pearl Gold, Dark Turquoise, Dark Tan, Dark Blue, Dark Red and Medium Dark Flesh are represented. The model is not as dark as it sounds though. :) The construction starts with the cellar embedded in a rocky landscape, including a small stream and the stair bridge leading to the entrance. A small steam engine is hidden in the cellar, which can also be moved via the axis leading outwards. Fortunately everything works well - since the building was designed completely digitally, the practical test might have brought some surprises. There is also a small astronomical model showing sun, earth and moon. On the dark red first floor there are bookshelves in a rounded SNOT wall, a microscope, a gramophone and a large hourglass. The second floor changes color to classic red and houses a chemistry laboratory, a camera, Pavlov's dog with bell and food bowl, a double-slit experiment in the corner, and Schrödinger's cat. According to the experiment the cat has to stay in the closed box. Actually, it's just a thought experiment, but that's hard to show in LEGO... On the third floor (color here: Medium Dark Flesh) there is a scale, a radio telegraph with Morse key and the mechanism for rotating the dome in the observatory. A round window makes it necessary to install a grille in overhead orientation. The walls of the observatory are again built sideways and there are also two small windows in the rounding. The final touch is made by the rotating dome with telescope, the windmill and the small apple tree next to the bridge. A little tricky is a step when attaching the dome. But once you've done that, the dome sits clean and can be turned 360° with the silver knob. For the complete rotation, a change to the chimney was necessary compared to the original design, which will also be included into the final model. A second small change to increase the stability of the model is also planned. Apart from a few little things the first version of the instructions was very well done and the test build was successful! At BrickLink they really put a lot of thought and effort into the whole program to make the resulting sets (with instructions etc.) as good as possible. I am looking forward to the finished set! Greetings, Thilo
