Showing results for tags 'assault gunboat'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Minifig-scale Alpha-class Xg-1 Star Wing (06-03-2013) Small update replacing the pictures with a black background by ones with a light one. (06-03-2013) For improvement of general swooshability! I've updated the internal structure to something that is way way way more stable (I can't stress this enough). If you're thinking about building: use these new model files (2.0). Really. Throw away the old ones. The result? See? No more hanging parts and disintegrating sidepods! Much better. (02-03-2013) It's done! I've added a build report below (after the files section). You know what they say: "A bird in the hand is worth..." (01-03-2013) So it turns out that real brick building is still rather necessary if you're inexperienced with 100% from scratch MOCs: the sidepods weren't strong enough to support the wing weight, so they have been redesigned internally. Also my solution for mounting the ion cannons on the sail didn't work as well in real life as it did virtually, so that has been modified as well. I'd strongly recommend getting and using the updated model files(posted below) if you're serious about building the model. Also, expect a write up of the build soon (with pictures! ) (30-01-2013) This model is now on Cuusoo! Please consider voting for it if you want TLG to make it. Thank you! (31-01-2013) I've updated the model to v1.2. The differences are all internal; the model should be sturdier now. IMPORTANT: if you're gonna build it using LDD instructions, please consider using the model-in-parts-file. This will force LDD to generate the instructions per major component (there's 9 in total), making it much easier to build. I've also added a wallpaper-like scene at the bottom of this post! (30-01-2013) New colors and updated images! ..or better known as the assault gunboat from the X-Wing/Tie-Fighter game series (Mu 1 anyone?). You can find more background info at this Wookieepedia entry. It's one of my favorite craft from the games, but unfortunately Lego never released an official set of it so far. As this thing cannot be missing from my starfighter collection*, I fired up LDD. It's my first 100% original, from-scratch MOC. Yay! I'm not really sure if I feel this model is done: I'm starting to suffer from "model blindness". Also the fact that there doesn't seem to be a definitive model of the Star Wing in the lore doesn't help. It's not even in the Essential Guide To Vehicles and Vessels. The model is rather bleyish, but for the love of me, I couldn't figure out a color scheme. I've included the LDD model below if you want to have a go at it, though I suppose most imperial craft are bleyish. So I'm hoping that you guys and gals can comment on whether or not I've done a decent job so far. Here are pictures so you can make your mind up (or you can just download the model file below). (minifig included for size) Some background info TL;DR: keep scrolling! The files are down below According to the lore, this ship is 10 meters long, 15.1 wide and 7.2 high. If my calculations are correct, that translates to 32x48x23 studs (about scale 1:40ish, which is minifig-scale). I believe the model is about that size (anyone got ideas on how to measure models?). It has 689 pieces of which none are rare according to LDD Manager. The model features foldable wings as well as landing gear and holds true to my "no flick-fire missiles in my house" policy. The ion cannons on the dorsal fin can rotate. There's a cockpit and the pilot has a chair. Because there are two technics axles running through the model (they connect the pods), it should be stable and probably quite swooshable. I won't find out until I build it of course (which may take a while since building the B-Wing burned through my budget rather quickly). If anyone has a better idea on how to construct the cockpit with these angles, please let me know. At first I used transparent panels on the sides of the cockpit, but they gave me design headaches up to the point where I was tempted to cut off the top bit (with the studs) from the panels to give the pilot some more room and raise him a bit so he can see outside the window properly. This is why I went with the small panel / transparent plate setup. I wanted to use this Windscreen 3x4x3 as it was the only one that kind of matched the angles I was looking for (when you use it on its side anyway). Files The main model file: v2.0 Model in parts (for building instructions): v2.0 (in parts) Play around with it. Maybe one of you can come up with a color scheme. Let me know what you think (31-01-2013) Here's a group of Star Wings patrolling around an ISD (click for big). *See my B-Wing MOC post: I collect starfighters from the X-Wing/Tie Fighter game series in minifig-scale. The Build I've finally managed to real-brick build the model! So here she is: Turns out that although building with virtual bricks gives you a lot of freedom to experiment, there is no substitute for real-brick building. In this paragraph I shall share some things I've experienced while converting my virtual model to something real. First problem I had was with the ion canons on the sail. Turns out my old grey frictionless pins are not fond of jamming bars in them. So I've opted for the solution shown below (which still looks rather neat). Then there was my "ingenious" solution for mounting these two canons really low and close to the sail. The original plan was to use a brick with an axle cross and jam the pneumatic "T" pieces in there, which oughta fit according to LDD. Turns out, they don't. Well, they fit, but (probably due to wear or tolerance) the brick doesn't hold them properly. Below you see the more standard solution for the problem. Note that in the new model file it is done slightly different, which you can also see in the first picture in this post. And then there was sidepod stability... my biggest problem (as I had predicted and feared). My original design turned out to be very fragile. As the picture below illustrates: just the weight of the main wing was already enough to have the assembly split and come apart (notice the black gap in the middle grey part). I've come up with a redesign that kind of works (I'll get to that in a minute). This is the main reason why, if you have already downloaded a model file and intend to build this thing, you should get the updated model files I've posted here. The version number should be 1.5. Unfortunately, that rework of the sidepods didn't stop the axles that connect them to the main hull from bending. The result of that is a model that looks like Star-Wars-meets-Salvador-Dali (apologies for the slightly blurry picture). I've already modified the main hull so that a pair of extra axles is present near the read. This helps, but doesn't stop the hanging. I'm afraid that if I want to make is internally strong enough, I've got to go with an entirely different solution. Probably lose the axles and use beams/thick liftarms instead. I might play with that after I'm done building my Missile Boat (coming soon ). The solution I'm using at the moment to combat the hanging is simple: support the sidepods! As you can see, I've used a 1x16 technics brick and it works really well. Ideally, one would use a 1x14 brick, but I don't have one. Sure, the stand is a bit bulky, but nothing I'm currently annoyed with. So it suffices for now. Other than these issues, the build went rather smooth. I was particularly happy with the sides of the nose: they are much sturdier than I expected, allowing me to remove one of the 4 connection points so I could make the internal cockpit a bit sturdier. I'm happy with how big it turned out; getting a sense of scale is always difficult when you work digitally. I hope you've enjoyed my little report and good luck if you attempt to build this!
