Showing results for tags 'all terrain scout transport'.
This is my ATST MOC. It has 597 pieces, is in mini-figure scale, and has every detail I could Pack in at this scale. While designing this I aimed for two things: show as little studs as possible, and full movie accuracy. I haven't seen any other mocs that meet both my goals as well as this one and I am very happy with how it turned out. The build is sturdy and well built for playability. It also has movable joints that can be adjusted for different poses. The head can rotate AND turn, something that I haven't seen in any other mocs. The hatch opens, and it comes with a full interior as well:The part where the head connects to the legs is one of my favorite parts because it was a challenge to design:The legs were also interesting to build because having them skinny and still movie accurate was hard.And the neck joint was probably the hardest to figure out because i had to make it rotate and turn, like shown :Here is an image of the bottom and right side:It also comes with a stand to help support it. The stand can rotate and turn to adjust to any angle you might pose it in: Here is a picture of the prototype i built. I dont have all the pieces needed at home, so it looks a little rough. But, some people requested to see it so here it is! This MOC is for sale. You can buy the instructions on: https://rebrickable.com/mocs/MOC-41267/AWproductions/at-st-movie-accurate/?inventory=1#comments
- 16 replies
UCS All Terrain Scout Transport (AT-ST) As featured in the The Return of the Jedi and Empire Strikes Back • by Corey Schaaf | BrickWars.net I started on this project in January of 2024. It's always my goal to try to build something that hasn't been attempted before. However, the AT-ST has been designed numerous times by the LEGO group. When I tackle something, my goal isn't for playability, but rather displayability. What makes this design so challenging is the front weight of the cockpit. While this build can stand on it's own (gravity gives it a much more menacing firing pose). I wasn't comfortable with the stress on the bricks. Because of this, I developed a clear stand. I must say, at first I thought it would detract from the build, but the details with the Forest Moon of Endor, coupled with the scale of the build, makes it blend in nicely. Like most builds, sometimes we have to sacrifice some screen accuracy for stability. In reality, the legs hinge like an accordion off the base. To achieve a similar result, I cheated and didn't leave any separation between the legs. I still created the look of the accordion connections, which enabled me to bridge the legs together for more stability. I once again worked with a manufacturer for a custom case (BrixBox.ltd), in addition to my signature Printed UCS Plaques and unique serialized tiles as well as UCS Stickers. Pieces: 3,797 + 3 Minifigs Weight: 122.8 oz | 7.7lbs Width: 33.5 cm | 13.2 in Length: 36.7 cm | 14.5 in Height: 43.6 cm | 18.2 in Estimated Part Costs: $490-$580 Only 250 copies of my manual were printed. At the time of this writing, 117 copies have been sold. If you're interested, I would encourage you to visit https://BrickWars.net/moc-bw4001. You can find all the details and specifications on my website. If you have any questions, feel free to ask! You can also give me a follow me on https://www.instagram.com/brickwarsnet/ as well.
- 9 replies
- legostarwars
- starwarsmoc
- (and 5 more)
