Showing results for tags 'a-wing starfighter'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Hello! this is my first actual moc post here, and hopefully far from the last. I hope you all enjoy this Resistance A-Wing design! I must give a big shoutout to Gumbinger, as a few elements are lifted from his RZ-2 design. I borrowed the general dimensions, the conical-shaped front deflector shield generators, but most notably the engine designs are almost exactly the same. I lowered the height of the top fins, but otherwise, I thought everything about his engine design was too good not to use. This design was the result of about a few weeks worth of first building in stud.io and then some back and forth of testing in real bricks and revising. Compared to the RZ-1, the RZ-2 has a lot more subtle, smoother and straighter angles. The angles coming from the front of the RZ-1 are slightly curved and round out at about the front of the cockpit, with the top and bottom surfaces becoming seemingly parallel with each other. With the RZ-2, the angles taper back from the front very evenly back past the cockpit, without ever really rounding out. This gives the side silhouette a very sharp triangular look, and it's one of the things I wanted to capture most. I feel like it turned out pretty well! The green markings on the red one stick out in an unfortunate way, I really had no idea how to incorporate them more smoothly into the design. They sit right on top of the old style 1x2 finger hinges. If I liked it less, it would be easy to remove the markings and just continue the white tiling. A small thing but I'm only just now noticing that the red 1x1 tile on the ship's left lower fin should be dark red, not white There are definitely a few areas that really could use improvement. Ideally, the panels on the middle sides of the ship could be stronger and easier to put together. It's not totally fragile or unswooshable but I don't love that area's construction either. There's also a good few gaps here and there, I feel like the part directly behind the windscreen could be more smoothly rounded, that area was surprisingly hard. I'm happy to accept all these flaws and just call this a version 1. After a while I'd like to come back and try to revisit all the problem areas in a version 2. Hope you enjoyed the model! If you're interested in buying instructions and parts lists, check out this flickr post for details.
