Showing results for tags 'Train loco'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. To use with my Ship to Rail transfer crane a small 0-4-0 dock shunter was needed. This uses a PF Train motor, AAA battery box and a PF Receiver. The aim was to make it as compact as possible - some slight mods needed to achieve this. PF train motor extended at each end by two 4 x 6 studded technic frames which clip into the locating points normally used for the buffer beam / couplings. Top of frame built up until level with studs on train motor and AA Battery box placed on top level with top of train motor. To achieve this a small hole was drilled through lower battery casing (through the centre ring between securing screw and casing end) to allow battery to sit on the train motor pivot pin thus securing that end - other end connects normally vis studs to the front 4 x 6 frame. PF receiver sits one brick behind battery box and is attached to rear 4 x 6 frame with a gap below to allow its PF cable to pass underneath. Both cables coiled up in the one brick space between battery box and PF reciever, the two side frames with doors helps to give more room for this. Body work built around AAA box and PF Rx. Yellow sticky back plastic film applied to battery box sides and colour is close match to lego bricks. I obtained the film from a road sign company. All studded surfaces covered with tiles. PF connector diguised as the engine exhaust. At first used decorative sides on the PF motor but they interferred with building the lower grey frame and were removed. Cab has a flat roof to allow loco to pass below my transfer crane and also the Block setting crane. I tried to add a centre wheel to make it a 0-6-0 but result failed. The engine is capable of pulling several wagons.
