Showing results for tags 'Mobile krane'.
Hi, guys! This is Alex - Yakov's son. My father was unwell a little. The heart infarction was alarmed at work, as a result. He asked me to lay out this model. I will tell in confidence, this crane very much is pleasant to me. Well, here you look... -Motor. 4-cylinder, in-line, mounted longitudinally. Due to the complex design of the windscreen and bonnet of rise small, it was decided to make transparent cylinders. Now when the vehicle can observe the work of the engine. - Steering. - Rear axle with differential. Torque is transmitted to the motor through a complex system of gears, due to the fact that the axis of the differential gear and the rack are aligned. -Side Support connected in pairs on each side and down-climb worm mechanism is used to drive the "curve starter." - Differential switch. It is possible to scroll the motor with the help "a curve starter". - The opening doors. - Lifting mechanism of an arrow. A little noisy mechanism, but it allows to fix an arrow in any situation. - The cargo winch is supplied with the same mechanism. - Maximum height. -I forgot to tell. The father with this model won first place at competition "LEGO Technic Russia". Competition was organized and carried out by Egor (rm8). yours sincerely, Alex.
- 12 replies
- Lego Technic
- Mobile krane
(and 3 more)
Tagged with:
