Showing results for tags 'Blakes 7'.
Hi, over the last two years I have been designing a new Lego spaceship in LDD 4.3, the Lego model is based on Scorpio from Blake's 7 which was a British Science Fiction series which ran from 1978 to 1981, due to the limits of Lego It is a 80 % accurate, the roof lifts off to reveal the hidden flight deck. The model is 163 studs long, 70 studs wide, 42 studs high ( 50 inches long, 22 inches wide, 12 inches high ), and has 11,981 pieces of Lego Currently redesigning the LDD Lego Scorpio Model to use less slopes and more SNOT Techniques. A side view of Scorpio A rear side view of Scorpio showing the engines The rear of Scorpio, with the two engines The Original Scorpio Model made for the Blake's 7 Series The View behind the transparent Lego revealing the mounting sockets for the custom light units which will be fitted into the built model View of the hidden apartment for the battary box, wiring and the two push to make switches The Front of the custom Lego Switches Rear view of the custom Lego Switch which two small push to make switches will be glued on to the bricks Side view of the Lego Scorpio View of main hatch closed View of main hatch open A view of one of the three weapon systems, with the other twin on the other side of the ship View of the Lego LDD Scorpio legs down View of the Lego LDD Scorpio legs up A view of the third weapon mounted under the hull of Scorpio A view of the top of the LDD Lego Scorpio A close view of the Radar Dish on the Lego LDD Scorpio A another view of the original Model of Scorpio for the Blake's 7 series Scorpio in Space A view of the flight deck with some stair which lead to the upper area and the entrance hatch A view of the flight deck in the Lego LDD Scorpio including the teleport area and front screen The flight deck of Scorpio from Blake's 7 A another view of the flight deck of Scorpio from Blake's 7 A view of the flight deck inside the Scorpio showing Slave (Scorpio's Ship Computer) and some of the middle section of the flight deck A view showing Slave (Scorpio's Ship Computer) Lego Clip Guns ( Chromed Star Wars Blasters), When I start building Scorpio enventually I will custom alter the Blasters to resemble Blake's 7 Clip Guns Blake's 7 Clip Guns View of the Lego Minifigure version of Vila, which will be a custom painted Minfigure View of Vila on Scorpio played by Michael Keating View of the Lego Minifigure version of Dayna, which will be a custom painted Minfigure View of Dayna on Scorpio played by Josette Simon View of the Lego Minifigure version of Soolin, which will be a custom painted Minfigure View of Soolin on Scorpio played by Glynis Barber View of the Lego Minifigure version of Tarrant, which will be a custom painted Minfigure View of Tarrent on Scorpio played by Steven Pacey View of the Lego Minifigure version of Avon, which will be a custom painted Minfigure View of Avon on Scorpio played by Paul Darrow View of Lego version of Orac (Super Computer) Orac in Blake's 7 The assembled Minifigure crew of Scorpio Close up of the LDD Lego Scorpio Crew The crew of Scopio in Blake's 7 The yellow stripe added to the LDD Lego Scorpio One of the recesses showing some pipes Just finished the rebuild of the new version of my LDD Lego Blake's 7 Scorpio Model, so far the rebuild includes just the front section A front view of the rebuilt front section of the LDD Lego Blake's 7 Scorpio A back view of the rebuilt front section of the LDD Lego Blake's 7 Scorpio
- 8 replies
- Blakes 7
- Terry Nation
- (and 4 more)
