Showing results for tags '75175'.
I was impressed enough by the new 75175 A-Wing set enough to buy it, but there are several flaws that can be addressed resulting in a much improved model. One aesthetic issue that stood out even from the earliest released images is the stepped transition of the curved slopes on the top of the hull. And while I really like the new fin parts and the attempt to angle them inwards, the official set's solution results in too much angle, a flimsy connection, and rather odd-looking brick-built engines. The landing gear is also less than ideal, with rear struts that don't fully retract and a front strut mounted higher than the rear, resulting in the model sitting very nose-down when landed. So I've addressed all of these points and included a few extra improvements to produce the version below. Features: Removed slope transition on top hull Brick-built engines replaced with cylinder bricks Engines/fins connected securely at corrected angle Fully retractable rear landing gear Front landing gear lowers to same height as rear Wider mounting of laser cannons Engine detail included under rear cover FREE LDraw instructions HERE.
Love the new Lego A-Wing, but I thought it was a little too narrow and wanted to fix a couple of things that bugged me. Mainly the overall shape and the engine angle.. I made it 2 studs wider, added some details to the front end, and adjusted the engine angles (also made them stationary). I'm not a big fan of the missiles, so I took them out and added some better landing gear. Overall, Im real happy the way it turned out! IMG_5810 by M G, on Flickr IMG_5814 by M G, on Flickr IMG_5815 by M G, on Flickr IMG_5811 by M G, on Flickr IMG_5808 by M G, on Flickr IMG_5809 by M G, on Flickr IMG_5812 by M G, on Flickr IMG_5813 by M G, on Flickr IMG_5807 by M G, on Flickr
