Showing results for tags '60018'.
DISCLAIMER: I am waiting on a replacement part from Lego Customer Service to arrive before I get on with making the review video! Well, this is my first review of a Lego set: the 60018 Cement Mixer! ...Or it would be, at any rate. Unfortunately, one of the most important pieces - a half-drum that makes up the mixer - seems to have cracked and bent in such a way that I can't actually use it. However, I did make a timelapse-y video of me assembling the set. Music: Airport Lounge by Kevin Macleod of incompetech.com [http://incompetech.com/] So, I picked up this set as an impulse purchase at the local Wal-Mart. I had a hard time of choosing between this one and three others that were priced the same - 4432, 60016, and 60017, to be exact. Since 60018 is a construction vehicle, I figured it would have the most play functions and thus I could review it properly. Some initial thoughts, good and bad: - This set feels fairly big and chunky for 20 USD. Not that I'm complaining... - Eight wheels makes this set irresistibly cool. - While the tilting front cab allows the minifigures to get at the plastic engine, it also makes the set a little awkward to pick up. - A good solid chassis composed primarily of a 2x16 plate and two 1x12 bricks adds to the swooshability. - The back end feels unfinished with all of its exposed studs compared to the front end, which has tiles as far as the eye can see. - A few pieces feel out of place, a couple could do with some printing, and quite a lot continue the tradition of throwing seemingly random-colored parts into odd places. My initial rating for this set: Good - consider buying if you have the spare cash! [This opinion might change once I get a proper review all figured out]
