Showing results for tags '5004590'.
Hi everyone, today here I am to show you my version of the Batpod. When 5004590 was released, everyone was thrilled and tried to replicate one on their own with their parts. However, 5004590 looks just strange when you compare it to the real one. I bought the book The Dark Knight Manual to understand the design more, and research on the Internet for a month, and finally I built a version that I think is closer to the real Batpod. The original Batpod is an escape pod from Batman's Tumbler, and the mechanism is based on the S-shaped axis. Each of the two wheels are connected to the body by one-sided arm only. 5004590 set does not do this while mine follows that design. The shape of the Batpod is also in a reverse V-shaped manner, without any horizontal element. The LEGO set did not do that at all, and my version tries to follow that original profile, with rear part elongated as well to match the proportion. Front view, which shows the asymmetrical design of the wheel axis. The front view has mounted 3 pairs of weapons, with headlights on the sides too. Middle part, which retains some of the details of the original 5004590 set. I like this part the most, which keeps the original design of the Batpod: mudguard between the two pedals. I tried to add some wiring to mimic the original, but it looks too busy and so I ditch it in the end. The whole exercise was started as an MOD, but with my design goals to rebuild the form in the most realistic way, I redid the entire chassis in the end. Looks like an MOC at last! Anyway, there is one technical issue that prevents the front wheel guns from holding permanently, but as a display model, this is perfect already. Thanks for watching!
- 12 replies
