Showing results for tags '42144'.
Hi Boys and Girls, I am happy to share my newest creation. Follow link for instructions More details here 3D-Play here This Grand Prix Air-Truck is an alternate build for official model 42144 Material Handler. All 805 required parts to build comes with this set and there is no need for other parts or other sets to build this Truck. In order to give this model a complete look, 7 spare parts are required that are all available with set 42144. Inspired by a real Race Truck, this model features: manual steering with knob openable doors on both sides tiltable cabin with lock V6 engine with moving pistons Pneumatic functions high-adjustable rear-axle with air air-suspension detailed design 32cm x 15cm x 15cm (38cm with open cab) In scale, this alternate build fits all mid-sized Trucks from the past years with the same tires and rims. Impressions Air-Suspension and how it works This model comes with Pneumatics and an adjustable rear axle that is connected to the V6-engine, where air-filled cylinders acts like shock absorbers. The lower the air-pressure is, the smoother the suspension works. The harder the air-pressure is, the harder the shock absorbtion works. The rear can be adjusted from low with no suspension to the highest point with full air-suspension. Instructions are very clear and understandable on how to connect Pneumatic-parts and tubes. Instructions Premium PDF instructions for this 42144 alternate build comes with 181 pages of high quality images and building steps to ensure a long and satisfying building experience. Following are example pages to show the quality of instructions: We will Truck you. This Grand Prix Air-Truck alternate build uses almost all parts from the given set 42144. Have fun with it.
- 42144
- alternate build
(and 4 more)
Tagged with:
Hello, I show you my latest build. It is a mod of set 42144. I was really disappointed by the aesthetic of 42144 material handler, but I think that the arm and the turret has been well designed. And I changed everything else. New tracked undercarriage, new tilting cab (not lifting) and new grapple (too look more similar to a demolition grapple). I tried to minimise the use of extra parts at the strength necessary. Instructions are available on rebrickable: here I hope you like it!
