Showing results for tags '42028'.
Hi, all, After lurking around the forum for a bit, I decided it was time to post my first MOC. This is a Star Destroyer, made from the parts in 42028 Bulldozer set. Overview: I started this MOC while experimenting with different frames and connections between parts. After some trial and error, I created a triangular frame with the sides bent in. Having just seen The Last Jedi, I was obsessed with all things Star Wars and decided to attempt an ambitious build for my low skill level- a Star Destroyer. Given that I am not the kind of person who likes to mix their sets together, I eventually settled on the 42028 set to create this MOC from- not only because the low parts count would provide a challenge, but also it would be kind of fun to see a yellow... Banana Destroyer? The frame was primarily constructed of beams and perpendicular connectors: (Note that this construction, while fitting together properly, created some stress on the parts- portions of the front push each other a bit owing to the tightness of the frame. But it's the best solution I could find given the space/ parts available. ) After that was complete, I built the engines and the distinctive cabin and attached them: Features: Authentic body shape Posable turbolasers Built entirely from parts in 42028 Bulldozer set Detailed engines and cabin More Pictures: I hope you enjoyed my MOC! Thank you for stopping by, and I appreciate all feedback, comments, and suggestions! Regards, Magical Duck
- 15 replies
- star destroyer
- 42028
(and 2 more)
Tagged with:
